Temp sensor problems....
dext924
Post by dext924 » Wed Aug 03, 2011 9:52 am
we are currently enjoying Europe again, and while driving to Trier the temp alarm started beeping at me. When I looked down, it ready 00, as though engine temp was 0c. For the rest of the day it read 0 and when I started it this morning, it read 16. Has anyone else had this problem? I have checked all connections and it is hooked up fine.
Any thoughts :?
Re: Temp sensor problems....
Post by haydn callow » Wed Aug 03, 2011 9:58 am
Sounds as though the sensor cable has been damaged....which temp alarm do you have ??
dext924
Post by dext924 » Wed Aug 03, 2011 10:33 am
Hayden, its the one with a green digital readout of the temp and voltage, that fits in the blank switch space, the small one. Not sure if you do them any more. Had it about a year as I bought it with the basic low temp sensor.
Post by haydn callow » Wed Aug 03, 2011 11:02 am
No...don't do them anymore...the guy who made them dissapeared during the riots in Bankok.
Have a good look at the sensor wire and make sure it's plugged in o.k......if not the best I can offer is to return it for me to look at.
dext924
Post by dext924 » Thu Aug 04, 2011 8:48 am
Thanks. I am back after the 15th Aug, so if I haven't sorted it by then, I will get in touch
Thanks again
dext924
Post by dext924 » Thu Aug 04, 2011 6:25 pm
Found the problem. While checking everything, I found a bit of the sensor wire had slipped on to the heat guard of the exhaust and melted it. So a quick repair and all is good again :D
