wheel bolts for rx8 alloys
Moderator: Ian
mikeyc1
Post by mikeyc1 » Thu Jul 28, 2011 10:19 am
Ok so I've got some shiny Rx8 alloys on my way to me now, question is, what size/type of wheel bolt do i need? any help appreciated
stuc
Re: wheel bolts for rx8 alloys
Post by stuc » Fri Jul 29, 2011 7:56 am
I used standard RX8 bolts, your local Mazda dealer usually has loads lying about if you ask them.
Redengine
Post by Redengine » Fri Jul 29, 2011 2:57 pm
I have just Bought my second Ford Freeda and see you are fitting Rx8 Alloys to yours. Could I ask you or anyone else will they fit straight on as long as I use RX8 wheel nuts? Can I use them with 225/45/18 tyres which are standard to the rims.
Mark
Post by missfixit70 » Fri Jul 29, 2011 3:08 pm
Tyres need to be load & speed rated at an absolute minimum of 96S, preferably higher, but the wheels can bolt straight on, although there has been some debate in the past about whether the wheels themselves are rated high enough for the bongo.
Redengine
Post by Redengine » Fri Jul 29, 2011 3:37 pm
Thanks for that.
What would you suggest as a better rated alloy?
Mark
Return to “Pimp My Bongo”
