hershambongo
Post
by hershambongo » Wed Jul 20, 2011 7:43 pm
Fuel gauge not working ! have seen the tips on Bongo Fury about re-earthing the sender ! but cant believe a new sender is £150.00 ! even looked on e-bay ! best price.......... yep £150.00 ! any ideas fellow Bongo people ? PS getting tiny little bubbles of rust over rear wheel arches ! We have no money and do I attempt to get some hammer-right & do this myself or leave it a while ?
HB
Post
by missfixit70 » Wed Jul 20, 2011 7:56 pm
Or just earth the tank to the chassis from underneath, should be a hole on the tank seam on the drivers side front, ripe for the job. Make sure you scrape back to bare metal to make a good connection on both ends & then splodge a bit of waxoyl over it when done.
Post
by missfixit70 » Wed Jul 20, 2011 8:13 pm
tallbongo
Post
by tallbongo » Wed Jul 20, 2011 10:04 pm
Others have covered the fuel gauge - it's an easy enough fix if it is just the earth.
Re the wheel arches - do something now!
The previous owners of our Bongo let the rust get hold in the rear arches. It didn't look too bad when we got it (a lot more than a few bubbles though) but a year later and the arches have disintegrated. We now face a bill of over 500 to get them fixed alone. The total bill for welding to sort out rust will easily exceed a grand.
Others may well have advice on how to treat the bubbles already there, but you need to prevent further oxidation (rust). This needs oxygen and either chlorine (from salts) or water. If you can seal off the arches from this you will at least slow down the rusting process. At a minimum waxoyl both the inner arches behind the interior trim (see the post on wheel arches further down) and also on the exterior try to thoroughly coat the seam where the arches meet. The aim is to prevent water ever coming into contact with the metal bodywork.
I'm no expert so hopefully others will be able to give more comprehensive advice, but do not just let it go.
95 N Reg 4WD Manual AFT Bongo
Diplomat
Post
by Diplomat » Wed Jul 20, 2011 10:41 pm
An engineer friend recently showed me the fuel gauge from an antique lorry.
It consisted of two parallel rods supporting a sliding float. Through the float ran a very slow thread Archimedes screw directly driving the gauge on top of the tank.
A classic piece of engineering.
Frank
They flew, I took up naturism
hershambongo
Post
by hershambongo » Thu Jul 21, 2011 1:18 pm
tallbongo wrote:Others have covered the fuel gauge - it's an easy enough fix if it is just the earth.
Many thanks ! HB
hershambongo
Post
by hershambongo » Fri Jul 22, 2011 9:59 pm
Many thanks all fixed ! thought it would be £150.00 plus labour job ! did iy myself ! well chuffed !
ChrisQ
- Bongonaut
Post
by ChrisQ » Sat Jul 23, 2011 7:59 am
Diplomat,
they still make fuel gauges like that, we have one that is exactly as described on top of the fuel tank in our narrowboat.
No electrics, just simple mechanics.
ChrisQ
