airbag sensor/removing drivers seat
nigelgibson
- Tribal Elder
just taking driver seat out to take to upholsterer and found an electrical connector. i think i read recently it may be to do with airbag. i need to disconnect but i'm wary of setting bag off ! - is it airbag related and if so are there precautions i should take or am i ok to disconnect?
Re: airbag sensor/removing drivers seat
Seatbelt warning light, not sure it's got anything to do with airbag TBH. Unless yours is fitted with an ejector seat?
nigelgibson
- Tribal Elder
Ejector seat - now there's a thought...!
Thanks for info , i must have mis-read or dreamed the airbag bit !
just disconnected it and no seat belt warning light !!
i thought i had a heated seat on mine, couldnt find a switch though
I was going to post that but thought I'd save you the embarrasment
and i only confessed, before you posted it up,
your safe its not connected to the airbag system, but i know what you mean most other cars sense the removl and deactivate the system, thats because most UK cars have anti-submarine doodahs in the seatbelt sensor, which is part of the airbag/restraint system
Julian
Julian
Part 57-900A http://lushprojects.com/bongopartsmk2/c ... f03.html#9
Anyone had the seatbelt clasp housing apart??
Looks like some sort of special screw head on the 2 screws holding the casing together..?
I have an inconsistent connection where the wire for this goes into the buckle clasp...
(The only thing electrical not happening!)
The wire runs sort of diagonal under the seat & runner to the just behind the bolt for the clasp at the side of the seat, so 16 years of the buckle movement swinging from 90 to 45 degrees (Aprox.) of adjustment has chaffed or broke the wire.!?
