Trouble with drivers side elecric window switch
Ely-freda
Post by Ely-freda » Mon Jul 18, 2011 10:10 am
Any help appreciated!
Our drivers side rocker switch has become loose and has now stopped working (window stuck down!) On taking it out and examining the plastic rocker switch it seems that the plastic is broken at the side of the switch ( white plunger and spring inside seem OK) therefore the switch will not opperate.
I find that a new switch assembly is £180 !!
Any help with a cheaper solution appreciated.
Thank you
Ely-freda
Re: Trouble with drivers side elecric window switch
Post by missfixit70 » Mon Jul 18, 2011 12:10 pm
There are cheaper compatible options - http://www.igmaynard.co.uk/bongo/forum/ ... switch+626
Post by Northern Bongolow » Mon Jul 18, 2011 2:01 pm
put a pic on here of the broken bit, i have some spare /old ones around,maybe possible to repair yours.
Ely-freda
Post by Ely-freda » Mon Jul 18, 2011 8:50 pm
Thanks for replies. Have looked at the link Miss fixit - very useful thanks. Tried Ebay but none on at present, will keep looking.
Thanks Northern - I have managed to tape up switch at present and it has got window closed but nothing else. So cant photograph tonight, but the part broken is the actual rocker push that you press on to operate the drivers window.
Kind of you to offer thanks.
cheers,
Ely-freda
Diplomat
Post by Diplomat » Mon Jul 18, 2011 9:01 pm
The slightest play in the rockers can mean that the slide switches below don't travel far enough.
I'm thinking of very carefully drilling right through the entire switch axis (driver and passenger switches side by side) and fabricating a strong axle and improved end bearings.
However it isn't quite 'broke' enough yet to justify fixing it.
Frank
They flew, I took up naturism
