Last week I changed the timing belt, tensioner and spring on the Bongo (diesel 2wd 1996). I was really careful to line up the timing marks top and bottom. I followed the fact sheet and used the Service Manual.
When finished I actually felt the engine was a little quieter/smoother but that's probably just my subconscious justifying the job. I didn't need to realign the sprockets at all but the previous belt did seem to have a fair bit of slack in it.
At this point I should note that I have a cube alarm monitoring two engine temps, 1 - the coolant measured at the engine hose stub) and 2 - the head temp measured at the back of the head.
On the test drive temp 2 (the head) seemed hotter than I was used to (up to 98c on hill climbs). Temp 2 remained in the range it's always been in 78-88.
So I did a full coolant flush (which took ages), changed the thermostat, a few hoses and bled the system up according to the Youtube vids.
The coolant temp is now lower and very stable, but the head temp is still operating in the same range.
My concern is before I did the cam belt change the Head temp seemed to operate cooler than it is now.
So, my thinkings on what's causing this: -
1. I've not got the timing right and would need to take it to bits again to recheck the marks.
2. The new belt has returned the Bongo to its correct timing (as the slack has been removed) and it now operates in the correct temperature/power/efficiency range.
3. When I cut the wires to the head temp probe and reconnected them with spade clips (too tired to get the soldering iron out) I've added additional resitance to the circuit and increased the temp reading at the Cube.
4. Post job paranoia - I should stop worrying and just get on with it
Any ideas? Thanks
