fuse for running water !!!
herb
Post by herb » Tue Jul 05, 2011 7:25 pm
as the title says we have, the sink in the bongo, and to get running water you put the switch in the down position( the one that looks like a fog light )but it doesnt light up and just wondered if any one knew which fuse it could be
thanks
M 80NGO
Re: fuse for running water !!!
Post by M 80NGO » Tue Jul 05, 2011 7:43 pm
Have a look under the bonnet near the leisure battery there should be a relay for the conversion electrics, this relay has a removable 15A fuse in it, mine has blown a couple of times so i've upped it to a 20A and it seems alright .
herb
Post by herb » Wed Jul 06, 2011 5:18 pm
thanks for reply , no leisure battery on vehicle ...
any other ideas
thanks
Post by g8dhe » Wed Jul 06, 2011 7:56 pm
Is this a conversion or are you referring to the Mazda Cube kitchen ?
If its a conversion then there is no simple answer as it was fitted by a 3rd party each in a different way! You need to tell us who did the conversion and if it has a name then someone with the same syle can perhaps comment, if its the Kitchen Cube then first turn on the Power Right-hand switch, and then the pump switch second from left;
