Will this work?!
bluemeadow
Will this work?!
Post by bluemeadow » Mon Jun 27, 2011 1:19 pm
Hi further to a question I posted on here last week about a compatible electric window switch I havent had any luck with breakers for the ones ones very helpfuly suggested on here but I have found this one on ebay, does anyone know if it will work or could be persuaded to work? Thankyou again x
http://cgi.ebay.com/ebaymotors/ws/eBayI ... OTORS:1123
Re: Will this work?!
Post by Northern Bongolow » Mon Jun 27, 2011 3:04 pm
looks very similar but the plugs are different, unless you are able to adapt it may be better to stick with the original.
bluemeadow
Post by bluemeadow » Wed Jun 29, 2011 10:19 pm
Ok thanku x
jaylee
Post by jaylee » Wed Jun 29, 2011 11:34 pm
My opinion.. Looks close & worth a punt..? May fit your existing Bongo switch plate/trim..? It will need connector modifying.. & if its anything like my 626, the rocker switch at the back (the one that isolates the passenger window) will go live when on...? I used mine as a panic button for total lock-down...
It may bug you that it looks a little different from the passy side too.. If i was in your position i would be 99% sure i could get it to function....!
