Air condioning Drain for condensate
Bluestreak
Post by Bluestreak » Sat Jun 18, 2011 2:21 pm
Hi everyone, does anyone know if there is a drain for any condensed water that could be trapped in the front heater/cooling unit at the front of the car?. my bongo gives out a bit of a smell when you first put the heater controls to the hot setting.
I wondered if it was water laying in the bottom of the heater unit. The coolant level does not move from month to month so don't believe it is a coolant leak of any sort.
cheers
Re: Air condioning Drain for condensate
Post by francophile1947 » Sat Jun 18, 2011 4:26 pm
It's probably bacteria. Gently clean the heater matrix and use your aircon regularly. You can also get aircon cleaner, but regular use is better and keeps the aircon in good condition.
Bluestreak
Post by Bluestreak » Sat Jun 18, 2011 4:40 pm
Thanks, is it relatively easy to get to the heater matrix?
Post by Northern Bongolow » Sat Jun 18, 2011 4:49 pm
about 20 mins get you in to it. remove the fan unit and service that while your in there.
Post by teenmal » Sat Jun 18, 2011 6:12 pm
Hi Bluestreak,
This might be worth a go,I used something similar about 2 years ago worked OK
http://cgi.ebay.co.uk/Aircon-Cleaner-an ... 27abde758b
Post by missfixit70 » Sat Jun 18, 2011 7:15 pm
Chances are the matrix is clagged up, every one I've seen has been, spend an hour or two cleaning it out properly, & you'll have a smell free system & it'll probably be much better airflow & cooler too.
lazyb5
Post by lazyb5 » Sun Jun 19, 2011 9:14 am
