Finally stumbled across a very small leak that has been mystifiying me for a while
- over the past 12 months I have had to top up my coolant by about 200 ml
I`m sad I know - I keep a small 500 ml bottle in the van with coolant in so if ever i have to top the system up I know how much I have lost.
Anyway after going over every hose, connection, coreplug and the radiator and found nothing I checked the end of the bleed pipe with the plug in and the metal clip on it I found the slightest trace of coolant.
I slid the clip back about 15mm so it was still on the plug and using a craft knife cut the hose using the metal clip as a straight edge and then cut from the clip to the plug and peeled the bit of hose off - because the clip was still on the plug there was no coolant loss - also had the hose clamped further down just incase.
Then slid the clip a bit further down and pushed the plug fully home and put the clip back in place - the plug was a pain to get fully home as the hose was a tighter fit and there is now no coolant there.
On closer inspection the end of the hose that I had cut off was thinner at the plug end than it was at the other end.
](./images/smilies/eusa_wall.gif)
Just thought I would post this as it could be an age related thing and one to look out for.
If I had all the money I ever spent on my Freda ............ I`d spend it on my Freda.
