Hi Everyone
After leaving home and travelling about 2 miles Bongo suddenly reduced speed to about 6 mph so stopped within a couple of hundred yards.
Putting in park and revving there was a knocking noise and black smoke from the exhaust.http://www.igmaynard.co.uk/bongo/forum/ ... ost&f=3#On switching off for a couple of minutes and restarting everything working fine.Drove back home ok.After a few hours took her out for a short drive about 5 miles and took her up to 80mph no problem.Any ideas what it could have been its a 2.5 diesel auto 1998 4 wheel drive
George
sudden loss of power
georgeb
MAZABON
Re: sudden loss of power
dunno:?: maybe a temporary fuel starvation problem
if you were revving it hard and black smoke came out that wouldnt be unusual from a diesel engine IMO, just clearing out the mucky carbon build up, perhaps that was the problem and you cured it
sometimes i give mine the full beans just to clear out the muck
other than that i dont know
rgds
rgds
is it a winterpack motor,with the little engine switch by your right knee etc.
georgeb
Yes ADY it is with the winter pack and it may have been switched on.Do you think that may have been the problem?
Sounds like a very likely suspect to me
If it's not something you normally use, may be a good idea to disconnect the switch?
georgeb
Will disconnect the switch.
thanks for the help
thanks for the help
