Donor Vehicle for Bleeding Demo
This year's event will be scaled down but it gives us a chance to get out!
Moderator: Ian
thedogsbollox
Post by thedogsbollox » Fri Jun 10, 2011 12:16 pm
As some of you know, i had a boil up on Tuesday and it looks like the problem is the Thermostat. I fortunately possess a Blueprint Stat that i will be fitting today. This will keep me going till i get to the Bash. I want to fit an Original Mazda one so if you need a donor vehicle at the Bash then i will hold off and we can do a Stat change/Bleed demo if that's cool.
Re: Donor Vehicle for Bleeding Demo
Post by Northern Bongolow » Fri Jun 10, 2011 2:03 pm
that will be fine tony,sounds like a plan as long as you can get it there.dont fancy doing it on the side of the m40 :roll: :lol: :lol: .
thedogsbollox
Post by thedogsbollox » Fri Jun 10, 2011 3:17 pm
Northern Bongolow wrote:that will be fine tony,sounds like a plan as long as you can get it there.dont fancy doing it on the side of the m40 :roll: :lol: :lol: .
Stat replaced, just waiting for the GF's sprog to get off to his dad's so i have a spare pair of hands/feet for the bleed.
Bunged the old stat in some hot water just to see if it opened and it did so keep your fingers crossed that there is not another problem.
Ady, you don't think my spotting problem on the tailgate would be coolant getting burned up?
Post by Northern Bongolow » Sat Jun 11, 2011 2:57 am
pm sent
Post by Ian » Sun Jun 12, 2011 8:04 pm
Ady, have sent you a text re: second donor vehicle.
Post by Northern Bongolow » Sun Jun 12, 2011 8:17 pm
thanks ian.
thedogsbollox
Post by thedogsbollox » Mon Jun 13, 2011 9:34 am
May not have mine to do now. As I have discovered the problem is the radiator then I will be able to drain and replace the stat while doing that. will keep yo posted.
Return to “Bongo Bash 2011”
