For all those that like to look at the coolent system. Pulling it to bits and generally have a poke around.
I have a radiator you might be interested in. (possibly pump and stat available)
Been over to France and Spain April / May. Bongo was great. over 1500 miles and many happy days.
However, when I got to the alp's, bongo not happy, got quite hot.
No overheating
No head gone it's fine. (please don't make this a head topic
had a slight problem, serviced the van, fitted new parts and it's as good as new.
Just running very warm, got the madason alarm fitted. Have it set at 4.5 and in England and Wales, probably goes off once in a while, big hills. Or stuck in traffic. Normally runs just past 12 o'clock, just off the picture, rising slightly on big hills.
But in the alps Running much higher than usual, 1 0'clock on the flat and higher on the hills.
Temp gauge running well past 12 o'clock much higher than usual. On hills heading for the red. Mason alarm on every hill and every time the van slowed down for the toll's, boy if you think fuel is expensive, nothing compared to toll roads.
Used the A/C and the rear heater to bring the temp back into the normal range.
Hottest it got was just below the red for about 5 mins, OOoooh
But even on Motorway's kept running hot. But we don't have hills like they do on the motorway.
So when I got back had the following done at Hillside Derby (bongo savy garage
New radiator (mazda part)
New thermastat (mazda part)
New belts
New pump (BGA) recomended by Hillside, they fitted dozens of them.
5 year coolent
Bank balance reduced by the same amount.
Any way the bongo is fine now, temp gauge is back down, running below 12, o'clock, certainly seem's to be much better.
Just thought given the above and the changes, one or two of you might like to get your hand and cutting tools on a radiator to see what has been going on. (the other stuff seem's to be fine, Thermastat was a Bongo fury shop one fitted 18 months ago) Was planning to keep them as spares as it was the garages opinion that the rad was the problem. Just for information they did the bleed back in January this year. And as I say they are bongo savy and have bleed dozen and dozen's of bongo's.
Get in touch if you want it, and will sort something out.
David.
