Should I be worried by empty expansion tank?
Hello all,
First time post, first time bongo owner.
Bought from a reputable bongo specialist, and only driven 50 miles home. Expansion tank empty, but was full when I left their premises.
Would you agree that an empty expansion tank is proof that (all else being well), the system has not been bled properly?.
Re: Should I be worried by empty expansion tank?
I'd get on the phone ASAP to where you had it from
Bongo no more........... ;-(
- haydn callow
DO NOT DRIVE IT..........DO NOT JUST TOP IT UP AN DRIVE IT.......get the dealer to collect it..
you will be doing both of you a favour
Either not bled or you got a leak or more serious problem, as already said, get onto them pronto, do not just top it up & drive, I'd at least want the coolant system pressure testing then bled properly just to make sure. Good luck
Damn you Haydn, beaten again, I must be getting old
If they are a "reputable Bongo specialist" they will appreciate the importance of not just "topping it up".
If they don't, then they aren't a "reputable Bongo specialist".
Thanks very much for your prompt & helpful replies.
They haven't even bothered with any summer coolant/antifreeze - just water if colour is anything to go by
Agreed - I meant allegedly reputable !scanner wrote:If they are a "reputable Bongo specialist" they will appreciate the importance of not just "topping it up".
That is terriblecheeseorham wrote:Thanks very much for your prompt & helpful replies.
Get the dealer to collect it straight away
- haydn callow
whereabouts are you based ??
- widdowson2008
As already said (several times) - get the dealer to sort it. If not dealt with, it could be potentially expensive.
Steve
Thanks. Everyone's point accepted and acknowlegedwiddowson2008 wrote:As already said (several times) - get the dealer to sort it. If not dealt with, it could be potentially expensive.
Prefer not to comment on location right now for obvious 'dealer' giveaway reasonshaydn callow wrote:whereabouts are you based ??
But if you do, someone may be local to you that can have a look see? you can put you approximate location in your profile by clicking on user control panel.
Haven't we heard this before about an alleged "reputable dealer"?cheeseorham wrote:Thanks very much for your prompt & helpful replies.
Anyone able to pm me the name of a previous alleged reputable dealer ?.scanner wrote:Haven't we heard this before about an alleged "reputable dealer"?cheeseorham wrote:Thanks very much for your prompt & helpful replies.
