Reversing mirror & MOT
Grahame at work
will a cracked reversing mirror be a problem for the MOT?
Regards Grahame
Regards Grahame
Joanie2 has had a sex change and is remaned Bert
- haydn callow
Re: Reversing mirror & MOT
If you mean the one hanging over the tailgate window, I think the answer is a defo NO it will not affect the MOT
Grahame at work
- The_Gordons
Ours went through it's MOT in March with a cracked tailgate mirror.
Bongo replaced by Wellhouse Terrier
Any stories about how they get cracked?
Is there a pattern which might highlight cracking risk?
Frank
Frank
They flew, I took up naturism
Who knows Frank..?!!
"Locker punched" by passing fools..?
Slight inherent glass fitting stress compounded by years of boot slamming...?
..Or my favourite.. the Judderman!!
The Kwickfit wheel aligners arch enemy number 1.
This guy causes surface rust too!
The bird, of course NOT the man in the make-up...
Grahame at work
It happened on my last Bongo as well - both times it was late winter and I suspect the cold / frosty conditions as on both occasions it was cracked in the morning but not the evening before.Any stories about how they get cracked?
Regrads Grahame
- helen&tony
aha...the mystery solved....it will fuse together again when the weather warms up!
Mine cracked on a 200 yard drive from one end of a car park to the other in zero degrees on smooth flat ground at slow speed! Jagged crack from left to right... or from right to left depending on which way you look at it!Diplomat wrote:Any stories about how they get cracked?
Frank
Alas Helen no it doesn't.helen&tony wrote:Hi
- The_Gordons
Ours cracked overnight during the really cold spell earlier in the year.
Hmmm... so the trend is implying that it's extreme cold that is killing some of them? I wonder why only SOME though?
Now i come to think of it... It was REALLY cold! So much so that i used the very rarely used REAR blowers... I wonder if some of that heat transferred and cracked my lens? But didn't crack the rear screen... Flip
that reversing mirror glass must be paper thin eh?
Depends how tight the mirror glass is fitted in the shell... Water/moisture gets in, freezes, expands, then crack!!!bigdaddycain wrote:Hmmm... so the trend is implying that it's extreme cold that is killing some of them? I wonder why only SOME though?
Possibly after a power wash???
