Installing a TV in the back???
SPARKYSSS
HI, I have just purchased a 16inch TV/DVD for the back of the Bongo. What is the best / easiest way to connect up to electrics please?? Can I just plug into the cigarette lighter?? Do I need an invertor??
Also any pics would be greatly appreciated.
Kind regards
Marc
Kind regards
Marc
- haydn callow
Re: Installing a TV in the back???
Is it a 12 volt TV or a 240 volt TV ??if 12 volt you can plug into a ciggy socket as long as it does NOT switch off with the ignition. (if it does switch off you can tap into the tailgate operated interior light.
If it's 240 volt I would forget it...(get a 12 volt one)....it would work on a inverter but inverters use power as well as the TV and really are not the best answer.
SPARKYSSS
MMMMMMMMMMM I think it may be a standard 240 one
- haydn callow
A lot of small flat screen TV's are able to work off both 12 & 240 volt.
I assume it has a normal household plug and lead with it you can plug into a wall socket....If this can be unplugged from the back of the TV (like a kettle" lead).....look for a small round 12 volt imput socket on the back of the TV and then you will need a small plug to fit that and either a ciggy socket plug on the other end or wires to tap into the bongo wiring.
SPARKYSSS
Thanks a lot Haydn. It hasnt arrived yet but when it does I will see what I can sort.
- haydn callow
It may even come with a 12 volt adapter which you plug into the hosehold mains..(like a laptop) if that's the case you have a 12 volt TV and you should be able to sort it....It will all be in the instructions.
Not being funny, but wouldn't it have been better to work out what you actually needed before you ordered it? I can never understand people watching TV whilst away camping anyway, too many other good things to be doing
- haydn callow
Sunday afternoon F1 GP or Moto GP ??
- haydn callow
You can record any channel (including BBC) with Sky +
SPARKYSSS
Oh the goggle box is not for me - its for my lad to watch as im usually tonking down the motorway.
Just had some extra info through
the seller has informed me its a MATSUI M16LUD709 POWER SuPPLY 12V -4.16A 50W
IT DOES HAVE DC IN 12V SOCKET IN THE BACK OF THE TV
So all should be ok
So all should be ok
SPARKYSSS
Sorry its a Matusui M16LID709 - Haydn - any ideas please?
- haydn callow
You obviously don't follow F1 etc......must be live
- haydn callow
You will be lucky to get any decent TV whilst bombing down a motorway
DVD will be fine
DVD will be fine
