v6 fuel injector down!!!
drew
Post by drew » Tue May 31, 2011 1:43 pm
hi all,
does any body know how to change a fuel injector on a 2.5 v6(petrol).?
can they be cleaned or does it have to be replaced?
and where can i get one from.
kind regards
drew
Re: v6 fuel injector down!!!
Post by g8dhe » Tue May 31, 2011 2:14 pm
Not an expert on this at all but never heard of anyone having problems here is a link to the diagrams;
http://www.lushprojects.com/bongopartsm ... no=.html#5 for the mechanicals (part numbers in the table or click the numbers themselves to open the list) and
for the electricals;
dandywarhol
Post by dandywarhol » Tue May 31, 2011 10:07 pm
drew wrote:hi all,
kind regards
drew
How have you diagnosed the fault is with the injector drew - what are the symptoms?
drew
Post by drew » Tue May 31, 2011 10:35 pm
hi dandywarhol,
it was last friday just before we were due to go away,the wife was on her way home when she rang saying that it wont go up the hills.
so when she got home i took it to a local garage were he said that i have a spark on all six leads but he thinks there is no fuel getting in number six piston.so on my way home from the garage i went up a couple of hills and it loss losing power,slowing down then it would change down in the gears and rev high.
no disrespect to the local garage but i am having it diagnosed on thursday by a specialist.
what do you think?
kind regards
drew
ps. had to sleep in a tent at the weekend, thank god for whiskey!!
dandywarhol
Post by dandywarhol » Tue May 31, 2011 11:43 pm
Find out if there's a signal getting to the injector and also take an ohmeter across the 2 terminals on the injector and see if there's a resistance http://www.fuelinjectorclinic.com/injec ... l/faq.html
Oh - and that'll be the Irish Whiskey you're drinking - not a patch on the Scotch Whisky 8)
Post by rita » Wed Jun 01, 2011 10:56 am
I usually use a piece of insulated brush shaft or similar and listen for the Tick at the injectors ( No Tick No Go) :P
Cheers.
drew
Post by drew » Thu Jun 02, 2011 1:03 pm
hi all,
just had the man who tunes cars and dianogstics. he couldn't connect to ecu because he didn't have the right plugs.but he checked the emissions and he thinks it is the lambda sensor not working right.all six injectors are working which is good news.
how many lambda sensors are on a 2.5 v6?
regards
drew
Post by g8dhe » Thu Jun 02, 2011 1:34 pm
There is only one Oxygen (Lambda) sensor B4-22;
http://www.g8dhe.net/bwm/bwmanualp.htm?1997/Page_40
