Charity LCA (Low Coolant Alarm) fitting
This year's event will be scaled down but it gives us a chance to get out!
Moderator: Ian
Post by haydn callow » Thu May 26, 2011 7:17 pm
As in the past at the Bash...I intend to attempt to raise money for my chosen charity....
See this topic for details and to vote PLEASE USE YOUR VOTE.
http://www.igmaynard.co.uk/bongo/forum/ ... 69&t=47823
The deal is this.....Buy a LCA and I will put £5 into the charity.......ask me to fit it and I will, for a £10 donation to the charity.
If you would like to take advantage of this ...PLEASE let me know and I will work out a fitting timetable to suit us all.
I will be available from first thing Thursday untill late Sunday
Please help me to raise loads of money by making your VOTE NOW (the RP charity)
Re: Charity LCA (Low Coolant Alarm) fitting
Post by Northern Bongolow » Thu May 26, 2011 7:20 pm
=D> =D> =D> =D> =D> =D>
Post by haydn callow » Fri May 27, 2011 5:22 pm
Ah !! I see the Vote/Poll has closed.
chooyuhudson
Post by chooyuhudson » Thu Jun 09, 2011 11:06 am
Hi Haydn I would like a LCA fitting if possible? I am there Saturday and Sunday morning. Kind regards David
Post by haydn callow » Thu Jun 09, 2011 12:20 pm
Come and find me Sat Morning....around the trade area.
bongobaz
Post by bongobaz » Thu Jun 09, 2011 12:24 pm
Great offer. Take advantage folks mine has saved me twice
Thanks Haydn!
Always be ready for a Top Up!
Bongo Bluck
Post by Bongo Bluck » Wed Jun 15, 2011 1:50 pm
Hi Hayden,
I would like to book in for a fitting, I'm comming late Friday night and leaving after lunch time on Sunday. If you can fit me in, whenever is fine by me.
Thanks,
Charlie
Post by haydn callow » Wed Jun 15, 2011 9:19 pm
come and find me when you arrive..around the trade area
Wilko70
Post by Wilko70 » Thu Jun 16, 2011 10:34 am
Hi Haydn,
Just seen this and would like to take you up on your offer, arriving Friday evening s o around sat and sunday. As in posts above shall i come find you?
Post by haydn callow » Thu Jun 16, 2011 10:38 am
Yes please......Fri when you arrive or Sat Morning.
Wilko70
Post by Wilko70 » Thu Jun 16, 2011 10:44 am
Will do, had been thining about ordering one but not got round to it yet. Thne hose split at the weekend, luckily on drive not whilst driving, however has now made my mind up to get this done sooner rather than later. Ordered new hose to arrive from Fury shop tomorrwo and mechanic fitting on monday. So all being well i shall se you there.
A cheeky question if i may, should i pass on any bleeding tipps to the mechaniconce the new hose is fitted?
Post by haydn callow » Thu Jun 16, 2011 11:47 am
Defo ...make sure he knows how to do a BONGO.....if he hasn't done one before download the factsheet and watch the utube Vid's "bleeding Bongos" if he does not do it correct we may not be seeing you at the bash......and how are you getting it to the garage.....don't drive it.
Wilko70
Post by Wilko70 » Thu Jun 16, 2011 12:11 pm
Cheers for reply, i'll print off factsheet as you say to take in..he has been named on the forum as being used previously and fuuny enough has been my mechanic on various motors over last 12 years or so...so hopefully ok.
RAC have done temp repair on hose so i can get it to garage.
Post by haydn callow » Thu Jun 16, 2011 12:25 pm
They may have repaired the hose but did they bleed the system when they refilled it ???? if NOT....do not drive it......result could be a bill for £2000.....I'm not trying to scaremonger....it's just the way it is.....
Did you drive it home after they repaired the hose ????was the tank under the bonnet empty at any point ??? Did the temp gauge move to HOT ?? even If the tank did not go empty air could have entered the system via the burst hose..
BE VERY CAREFUL
Wilko70
Post by Wilko70 » Thu Jun 16, 2011 12:32 pm
Car was on drive which was fortunate, but yes they did bleed the system amd the guy was telling me about importance of removing all the air. Then ran the engine for a good while until warmed up to ensure bottom hose was getting warm and coolant was circulating, so hopefully done a reasonable job. Temp gauge reached the classic 10 to 1 through this exercise and didn't get higher than that.
Return to “Bongo Bash 2011”
