Glow plug relay
scots_jon
Glow plug relay
Hi all,
"Bertha" wouldn't start this morning and a few minutes with a meter has turned up a faulty glow plug relay. However when I went to look for a replacement relay, the only options I could find were over £80! The parts database doesn't list an alternative part. Has anyone found an alternative with the same terminals? Or should I just put in a cheap generic relay?
Cheers,
Jon.
Cheers,
Jon.
Re: Glow plug relay
can you post some picies,of the numbers on it and the terminal layout etc,i may have something
scots_jon
Re: Glow plug relay
Piccie below. It seems to be very similar to http://www.e-jbc.biz/relay-mr8-eng.html It is just a simple SPST relay.
- helen&tony
Re: Glow plug relay
If anything come of this, let us know...I reckon the Bongo needs new Pluggies, and IF the relay is available cheaply, I'll replace that at the same time and be done with it!
Re: Glow plug relay
My brother in law works in the motor trade and searched for a cheaper alternative but failed.
I opened up the relay and found that the copper wire had come away from the soldered joint, I resoldered it and it works fine.
Daz
Daz
Daz and debs
Re: Glow plug relay
Ooh now that sounds like a good tip. Thanks wormeywormey wrote:My brother in law works in the motor trade and searched for a cheaper alternative but failed.
Daz
Re: Glow plug relay
This may help
- http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=49190
scots_jon
Re: Glow plug relay
Cheers! I'd already stuck in a standard 70A relay, but mine was only £5.54 from VWP... Funnily enough, I was also planning to add an LED in the dash to show voltage at the glow plug rail to help diagnose starting problems in the future.missfixit70 wrote:This may help- http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=49190
Re: Glow plug relay
The glowplug factsheet in the members area may be of interest, there's a mod in there to fit a glowplug switch with an indicator led so you can see when they are on & switch them off when not necessary - http://www.igmaynard.co.uk/bongo/member ... wplugs.pdf
