Moving my dangly into the rear cluster (V6)
- Pablobongo
can any one point me to an "idiots guide" on how to do this?.......really have not got a clue where to start, but i do hate the way the dangly spoils the lines of my body kit!!
Paul 2002 V6
- dandywarhol
Re: Moving my dangly into the rear cluster (V6)
You strip the offside lamp cluster, cut a hole for the bulb in the lowest "spare place" for a bulb and fit a 21W bulb in.
There's a "how to" with pics by missfixit somewhere in search.
dandywarhol wrote:You strip the offside lamp cluster, cut a hole for the bulb in the lowest "spare place" for a bulb and fit a 21W bulb in.
And make sure that you make a hole big enough for it (your dangly) to fit comfortably!
Frank
They flew, I took up naturism
MAZABON
- Pablobongo
sorry, not replace it with a flush fit bumper one......actually house it in the right hand rear light cluster
Paul 2002 V6
MAZABON
ahh, think they look quite good in the bumper though
think dandywarhol is refering to this
http://www.igmaynard.co.uk/bongo/forum/ ... +fog+light
- You've Been Bongod
no need to do any cutting
i have my rear fog in where the reverse light was all i done was cut the reverse light wires and connected the dangly wires oh and put a red bulb in job done
As has been said many times before though Carl, doing it the way I did it on the thread above, by adding the foglight in the "spare" reflector, you don't lose a reverse light (Yes we know you fitted a reverse camera & didn't need it, but some of us still need it
) Even Dandy came around to the idea eventually
- Pablobongo
Thanks, although i have just taken my rear cluster off and it is different to yours (mines a 2002 model), but i think it can still be done....there seems to be space just below and to the side of the rear tail lamp, although i am not too sure if this would interfere with the light being given off by the tail lamp when both this and the fog lamp are switched on....?bongobaz wrote:
Paul 2002 V6
Stick a pic of yours up then.
