coolant alarm
phatgit
coolant alarm
Post by phatgit » Fri May 20, 2011 8:32 pm
just wondering what temps other peeps are running,mines around 88-93, bit warmer with the heater off around 90-95.
thought if we can find an average, would know if were running into trouble!!
TechnoTurkey
Re: coolant alarm
Post by TechnoTurkey » Fri May 20, 2011 9:12 pm
Mine used to run at 94 and after changing the water pump, thermostat and flushing then refilling with Carplan Premium Red Coolant it runs at 87/88 steadily.
I wouldn't worry at the temperatures you are reporting, but you may be able to lower them with a bit of maintenance on the cooling system, I'm very glad I did mine and it wasn't that hard.
Before anyone else chips in, this is with the sensor on the back of the bloc as per the instructions, other locations will produce different temperatures.
Member 10,000!
1997 Green AFT 4x4 2.5TD Auto Bongo
Re: coolant alarm
Post by missfixit70 » Fri May 20, 2011 9:16 pm
