BONGO BEEPS
alant54
BONGO BEEPS
Post by alant54 » Sun May 15, 2011 12:17 pm
Hi all.....I have just watched the video for stopping the beeps on a Bongo....unfortunately this stops ALL the beeps..most of which are SAFETY features..... :shock:
The only beep which annoys me is the key in ignition with door open one...can't have the door open with key in to listen to the radio... :cry:
There is an easy way to cure this....remove the bottom of the cowl on the steering column...3 screws from underneath.
At the key end of the ignition switch you will see two wires ( one red/yellow one green ) these go to a plug/socket at the back end of the switch.....you can slide this unit towards the front of the Bongo to remove it ( you will need a small terminal driver to release the retaining catch )....Then if you remove the plug with one purple and one white wire into it then this will stop the key/door beep whilst retaining all the other SAFETY ones.... =D>
Slide the socket back on and tuck the plug part away... replace cowl...job done.. :lol:
Hope this helps you folks... :wink:
Alan
Alan...still plodding on....!
alant54
Re: BONGO BEEPS
Post by alant54 » Sun May 15, 2011 2:23 pm
If anyone does the above could you please report back on it and if it is ok then maybe it can be put on a factsheet.... :)
Alan
mister munkey
Re: BONGO BEEPS
Post by mister munkey » Sun May 15, 2011 3:21 pm
Good tip Alan!
I went for Plan B which involves just unscrewing the door switches that make the little light come on when the doors are open.
Stops the beeps but does involve a stretch of the arm in the dark to manually flick the light on.
I've learnt to live with that though.
longhaul8
Re: BONGO BEEPS
Post by longhaul8 » Sun May 15, 2011 3:27 pm
Great tip =D> =D> =D> but i went for the other option had the stereo connected to the lesuire battery same with the blinds and anything else i may need while parked so keys can live in my pocket.
But will still proberly follow your tip when i get time anyway :D :D :D
dreamwarrioruk
Re: BONGO BEEPS
Post by dreamwarrioruk » Sun May 15, 2011 3:57 pm
this method prevents the reversing alarm from bleeping unless the lights are on though. this was the first job i did when we got our bongo. disconnect that annoying "ive left my keys in "alarm.
mike, jo and emma
lazyb5
Re: BONGO BEEPS
Post by lazyb5 » Sun May 15, 2011 5:25 pm
i removed the 2 wires from the beeper which is next to you foot. One for the reversing alarm and one for the keys in. All safety alarms left intact.
campergeek
Re: BONGO BEEPS
Post by campergeek » Sun May 15, 2011 6:57 pm
What are the safety beeps for? My bongo has no beeps at all :shock: Am I missing out on something? Glad the roof doesn't beep, but would be nice to know if I leave the lights on.
Re: BONGO BEEPS
Post by g8dhe » Sun May 15, 2011 8:14 pm
You don't need to remove the cowl, the plug and socket can be reached without it, there are photo's showing the position of the plug and socket but not in a position to locate them at the moment
alant54
Re: BONGO BEEPS
Post by alant54 » Sun May 15, 2011 9:08 pm
dreamwarrioruk wrote:this method prevents the reversing alarm from bleeping unless the lights are on though. this was the first job i did when we got our bongo. disconnect that annoying "ive left my keys in "alarm.
Hi Mike...long time no see... :wink: ....my reversing beep still works with or without lights....funny things these Bongos... :lol:
g8dhe wrote:You don't need to remove the cowl, the plug and socket can be reached without it, there are photo's showing the position of the plug and socket but not in a position to locate them at the moment
I had already had the cowl off as my immobiliser has packed in and I was in the process of trying to by-pass it to get my electrics working..... #-o ....without the cowl I found it much easier to release the retaining clip on the plug....it only takes a minute to remove and replace.... :D
Alan
alant54
Re: BONGO BEEPS
Post by alant54 » Sun May 15, 2011 9:52 pm
campergeek wrote:What are the safety beeps for? My bongo has no beeps at all :shock: Am I missing out on something? Glad the roof doesn't beep, but would be nice to know if I leave the lights on.
Apart from the annoying key in/door open.....there are beeps for
Lights on/door open
When in reverse
When roof is raising...stops when roof fully up
When the Granny squash button in the roof to lower roof is pressed
When roof is being lowered...stops when roof is fully down
If you attempt to drive off with the roof up
To me these are all safety features....... :wink:
Alan
campergeek
Re: BONGO BEEPS
Post by campergeek » Sun May 15, 2011 10:26 pm
Thanks Alan. Might try to reconnect it then, but doesn't sound like I'm missing out on much.
Alacrity
Re: BONGO BEEPS
Post by Alacrity » Mon May 16, 2011 1:26 pm
I disconnected the connector on the steering column, all beeps still there apart from the irritating 'key in' one. :D
dunslair
Re: BONGO BEEPS
Post by dunslair » Mon May 16, 2011 2:13 pm
You could still hear the radio with the door shut and the window open / down.
gasace
Re: BONGO BEEPS
Post by gasace » Mon May 16, 2011 6:26 pm
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=45347
This is what I have done, everything working apart from the bleeping key
nicstrike
Re: BONGO BEEPS
Post by nicstrike » Mon Jul 04, 2011 10:00 pm
lazyb5 wrote:i removed the 2 wires from the beeper which is next to you foot. One for the reversing alarm and one for the keys in. All safety alarms left intact.
which 2 wires are they? when we originally got the bongo i disconnected the big plug on the unit behind the kick panel. silence is golden but i did miss the lights on alarm. so i have now re-connected the main box & pulled the plug on the back of the ignition switch. better but i also really don't need to be told that i am in reverse , the fact that that there is a big "R" by the gear selector staring at me and i'm probably going backwards is another clue to that! i had been wondering wether there was another feed that could be disconnected to silence the reverse alarm but a "one stop job" definitely sounds preferable to having various bits of the loom un-plugged and cable tied up out of the way.
