Rad fans not coming on
thegreenman
- Bongonaut
I have just noticed myrad fans don't come on under normal driving conditions.
Removed the connector from the temp sensor and they fire up OK
I am assuming a sensor fault, but can't see a replacement part in the shop section
Does anyone know where I can get a new temp sensor?
TIA
TIA
Re: Rad fans not coming on
They won't come on until the engine is getting too hot - I've very rarely had mine come on and I am not overheating
- mikexgough
Mazda do them if course and so do the usual Bongo spares suspects....Mazda package the Denso 179700 0220 up as O.E
Jas shows the fitment on their site
I replaced mine, a) my fans rarely run like Franco's and b) the plastic socket on the end of the sensor was looking aged so for me worth the cost to change......needless to say after I had changed the sensor, I ran the engine to the point where the double speed fans run...to check it out....
to test the switch remove it carefully, and watch out for the ally sealing washer.(the grey plastic end breaks off,or at least can be loose) use a deep socket. when placed in water it should be open(no flow of current through) when the water gets to approx 96 deg c the switch should close (circuit).
this switch also controls the fast idle on/off, and the glow plug info to the ecu so needs to be in good condition so a good quality replacement should be used for such a key component imo.
- crazy uncle gray g
another way to test is to run her up on your drive for 45mins
with the heaters off, watch your temp gauge and you should find
that with no rushing air flow through the rad the fans will kick in
cheers! party on dudes.
- brorabongo
You can also quickly test to see if the fans work by disconnecting the sensor....
http://www.igmaynard.co.uk/bongo/forum/ ... gy#p378116
thegreenman
- Bongonaut
thanks all, pretty sure it has failed. Fans come on when I disconnect it. Will remove it for testing asap.
- widdowson2008
Agree with John and crazy uncle gray g. Fans will only come on when the stat has lost control (96 deg.C), so if your system is OK, then you will probably never hear them (unless you have the aircon running).
Steve
dont forget you will have to bleed the coolant system if you remove it to test it.thegreenman wrote:thanks all, pretty sure it has failed. Fans come on when I disconnect it. Will remove it for testing asap.
If the switch fails, ie open circuit, the fans stay on permanently, so as has already been repeatedly repeated, yours is probably fine
Rad fans should not come on during "normal" driving conditions. If you were stuck in traffic for more than 20 minutes with the engine running, you might expect them to kick in, or if you were going really slowly/heavily loaded up a steep hill mebe where there would be insufficient airflow across the rad to cool the coolant going through it. That's assuming of course that your stat is doing its job ok
- mikexgough
If your sure or suspect it has failed....just replace it.....don't waste time testing it....thegreenman wrote:thanks all, pretty sure it has failed. Fans come on when I disconnect it. Will remove it for testing asap.
mikexgough wrote:If your sure or suspect it has failed....just replace it.....don't waste time testing it....thegreenman wrote:thanks all, pretty sure it has failed. Fans come on when I disconnect it. Will remove it for testing asap.
Just test the new one
Waheyyyy - she's backmissfixit70 wrote:If the switch fails, ie open circuit, the fans stay on permanently, so as has already been repeatedly repeated, yours is probably fine![]()
- widdowson2008
Yep. Good innit?mikeonb4c wrote:Waheyyyy - she's backmissfixit70 wrote:If the switch fails, ie open circuit, the fans stay on permanently, so as has already been repeatedly repeated, yours is probably fine![]()
Rad fans should not come on during "normal" driving conditions. If you were stuck in traffic for more than 20 minutes with the engine running, you might expect them to kick in, or if you were going really slowly/heavily loaded up a steep hill mebe where there would be insufficient airflow across the rad to cool the coolant going through it. That's assuming of course that your stat is doing its job ok![]()
and this may explain fan operation
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=48872
Steve
