oil top up
flipflop
oil top up
Post by flipflop » Fri May 06, 2011 8:02 pm
need to top up the oil, bit low on dip stick but cant afford full change and new filter etc - which oil
should i use?
ta
Re: oil top up
Post by francophile1947 » Fri May 06, 2011 8:05 pm
Same as what's already in there - check with whoever did it last change 8)
flipflop
Re: oil top up
Post by flipflop » Fri May 06, 2011 8:12 pm
lol i would but cant get through on phone - does it matter if mix diff oils ?
Diplomat
Re: oil top up
Post by Diplomat » Fri May 06, 2011 8:12 pm
flipflop wrote:need to top up the oil, bit low on dip stick but cant afford full change and new filter etc - which oil
should i use?
ta
francophile1947 wrote:Same as what's already in there - check with whoever did it last change 8)
Ideally, new clean oil !!!
Frank
They flew, I took up naturism
scanner
Re: oil top up
Post by scanner » Fri May 06, 2011 8:15 pm
Not really but not ideal.
It should be 5W-30 or 10W-40 at a pinch.
For a top up if you are going to be changing anytime soon just use mineral, no need for Synth or Semi-synth.
flipflop
Re: oil top up
Post by flipflop » Fri May 06, 2011 8:17 pm
ta :)
Re: oil top up
Post by Northern Bongolow » Fri May 06, 2011 8:22 pm
make sure its for turbo diesels, 5w 30.
not petrol engines.
Re: oil top up
Post by teenmal » Fri May 06, 2011 9:20 pm
Hi flipflop,
If the vehicle is using oil you would be better using 10w/40 oil.
Always remember any oil is better than none.
Cheers..
flipflop
Re: oil top up
Post by flipflop » Fri May 06, 2011 11:23 pm
thanks guys x
lazyb5
Re: oil top up
Post by lazyb5 » Sat May 07, 2011 12:01 am
I always use 5-30 synth why do you say just use mineral scanner i thought that was for old vehicles :lol:
scanner
Re: oil top up
Post by scanner » Sat May 07, 2011 11:43 am
lazyb5 wrote:I always use 5-30 synth why do you say just use mineral scanner i thought that was for old vehicles :lol:
I said "IF" only topping up and "IF" intending to do a full change soon only use mineral to top up for now - save the good oil for the full change. No sense in using good oil if it is going to be thrown away soon.
Certainly use semi-synthetic or synthetic for a full change OR stick with mineral if you change it every 3000m.
