Sliding Door Stuck - not electrical
DanO
Post by DanO » Sun May 01, 2011 7:25 pm
Hey all
Went kitesurfing today (first decent run in the van) and on getting there the sliding door wouldn't open, turns out my mate had trapped his pump in the door when shutting it. The pump tube is compressible but at the end that's stuck there are about 3 different hard plastic adapters that are trapped. On looking at the lock from the outside it looks "locked" but the door wont move, obviously don't want to force anything and don't want to stick my fingers in, incase the "power close" (-whatever it's called) starts and slices my fingers off. Any one any ideas? Is it a case of inside panel off?
Not sure the photos help but they are here:
+ Image
P1000428 by DanO 1976, on Flickr
+ Image
P1000425 by DanO 1976, on Flickr
I've had a search but can only find topics regarding the relays and flat battery etc.
DanO
jaylee
Re: Sliding Door Stuck - not electrical
Post by jaylee » Sun May 01, 2011 8:07 pm
You could try pulling the blue 15 amp fuse on the bottom row?? (Cab fuse box.) & see if it disables the "soft closure" (motor pulling the door shut.) :-k Its worth a try for a starter!!? :idea:
Post by g8dhe » Sun May 01, 2011 8:09 pm
It looks as if the pump may have tangled with the lower front rolling support 72-250Z;
http://www.lushprojects.com/bongopartsm ... mgno=.html
if the end of the pump was in front of the support then I would have thought it would open with a bit of force, but it wouldn't close, if its behind the support then it would trap against the step and the door won't open but it ought to close with a bit of pushing. If its actually sat on top of the support then probably trying to pull it up whilst forcing the door closed might do the trick, but a bit tricky to say the least :-(
dobby
Post by dobby » Sun May 01, 2011 8:13 pm
or pushing out from the inside whilst trying to open the door?
Amazed it shut at all to be honest
jaylee
Post by jaylee » Sun May 01, 2011 8:15 pm
Go on... Cut the hose & try to force it into the cavity....! :wink:
jaylee
Post by jaylee » Sun May 01, 2011 8:23 pm
Arrrrrrrhh... I say she be caught betwixt a nether world, neitherrrr closed nor open. A Davey Jones lock up!!
jaylee
Post by jaylee » Sun May 01, 2011 8:26 pm
Just BLOW THE BLAADY DAW OFF...!!
dobby
Post by dobby » Sun May 01, 2011 8:28 pm
Hmmm Jaylee - no response thus far!
jaylee
Post by jaylee » Sun May 01, 2011 8:35 pm
dobby wrote:Hmmm Jaylee - no response thus far!
Early daze yet!!! :wink:
I expect success.... =D> 8) :mrgreen: [-o<
mikexgough
Post by mikexgough » Sun May 01, 2011 8:36 pm
If you need to get in the side door as that could be the "best" way of releasing the door......well I would do it that way
dobby
Post by dobby » Sun May 01, 2011 8:38 pm
jaylee wrote:Just BLOW THE BLAADY DAW OFF...!!
Pipe bomb
DanO
Post by DanO » Sun May 01, 2011 8:47 pm
:lol:
Thanks for the suggestions, I'll try tomorrow in the daylight..............disabling the soft closure first seems sensible, thought there would be some sort of "override" from inside but nothing obvious, will save my pinkies!! :oops: The lock is locked - the catch has come over and we can't seem to flick it back like the other door locks work.
We have tried gentle persuasion from inside but that doesn't seem to do anything, the handles also feel a bit too fragile to push harder.
Any other sparks of genius are welcome. oooooarrr!!!
dobby
Post by dobby » Sun May 01, 2011 8:49 pm
Do you know how to get the door card off etc? It can be a bit fiddly from memory. I've forgotten the tip for getting the handle off.
DanO
Post by DanO » Sun May 01, 2011 8:53 pm
I've got no idea.......used to simple VW T25 stuff where's it's obvious.......in the quick look we had earlier it didn't seem so simple. If you can remember it would be very handy!!!
jaylee
Post by jaylee » Sun May 01, 2011 8:54 pm
I'm wondering if the "child lock" has been knocked on too...? (Part 72-410Z Geoff's link)
... A series of unfortunate events.. :roll:
