Leisure Battery Size
Posted: Mon Apr 18, 2011 8:59 pm
by Paul
Can anyone tell me the dimensions of a leisure battery to fit in the LB tray.
Paul
Re: Leisure Battery Size
Posted: Mon Apr 18, 2011 9:11 pm
by daveblueozzie
Depend on which battery tray you have, if its a willinton tray you can squeeze a 110 amp LB
If its a Mazda tray you may have to measure the space and even bend the lip of the tray down a bit if you need a bigger LB that will fit .
Posted: Mon Apr 18, 2011 9:19 pm
by Paul
Thanks Dave, but its not the amps thats the problem its the Height, width and depth of the battery to fit the tray bought from the club.
Paul
Posted: Mon Apr 18, 2011 9:53 pm
by AlliDelta
Bigger amps = bigger battery. I have a 110ah in ours but it's a willinton jobbie.
Posted: Mon Apr 18, 2011 10:38 pm
by Jaws
Hi Paul
Spent a long time myself trying to find the info you are after and following a quick check with the tape measure you need something within 300x200x200mm as far as I can tell. Clearly my Bongo is not your Bongo and a larger size may be feasible
I use a pair of these:
http://www.elecsolbatteries.com/product ... l-100.html
which fit easily in either battery tray but there are plenty of other recommendations. I guess any battery recommended on the forum will fit but I appreciate that most people are more concerned with storage capacity rather than actual dimensions.
Hope that helps
Posted: Mon Apr 18, 2011 11:00 pm
by Paul
Thanks Jaws
Thats a great help as i don`t want to slam my bonnet down and hit the top of the battery.
Paul
