Can anyone tell me the dimensions of a leisure battery to fit in the LB tray.
Paul
Leisure Battery Size
No man can be what they want to be he can only be the sum of his experiances!
- daveblueozzie
Re: Leisure Battery Size
Depend on which battery tray you have, if its a willinton tray you can squeeze a 110 amp LB
If its a Mazda tray you may have to measure the space and even bend the lip of the tray down a bit if you need a bigger LB that will fit .
Lost without my Bongo.
Thanks Dave, but its not the amps thats the problem its the Height, width and depth of the battery to fit the tray bought from the club.
Paul
Paul
Bigger amps = bigger battery. I have a 110ah in ours but it's a willinton jobbie.
Hi Paul
Spent a long time myself trying to find the info you are after and following a quick check with the tape measure you need something within 300x200x200mm as far as I can tell. Clearly my Bongo is not your Bongo and a larger size may be feasible
I use a pair of these:
http://www.elecsolbatteries.com/product ... l-100.html
which fit easily in either battery tray but there are plenty of other recommendations. I guess any battery recommended on the forum will fit but I appreciate that most people are more concerned with storage capacity rather than actual dimensions.
Hope that helps
Hope that helps
Live Bongo and prosper.
Thanks Jaws
Thats a great help as i don`t want to slam my bonnet down and hit the top of the battery.
Paul
Paul
