Just wondering.
kawasaki kid
- Tribal Elder
Just wondering.
As the title says - just wondering - I`ve been two additional reversing lights hard wired into the factory reversing lights - but now it has come time to replace them as age and condensation has caught up with them - the question is if I were to replace them with one slimline 55watt H3 spotlight could I get away with not fitting a relay
or should I just fit two more 21 watt reversing lights. Have been using this setup for over two years without problems but they make the back end of the van look cluttered
and I need the extra light as I have to reverse park outside my house all the time so when it is dark you cannot see anything behind
- Yes I`ve got limo tints.
If I had all the money I ever spent on my Freda ............ I`d spend it on my Freda.
- You've Been Bongod
Re: Just wondering.
Ian if fitting spot lights i would always recommend using a relay as i put some on a car once and wired them directly to main beam and melted the relay after time costly experience to put right
