REAR AXLE OIL SEAL
carr
REAR AXLE OIL SEAL
Post by carr » Tue Apr 12, 2011 6:48 am
HELP NEEDED
Hello you all
The rear passenger side rear axle oil seal on my 2 wheel drive bongo has gone again this is the third time now.
I have checked the breather valve and believe this to be clear but how can I be sure ???
Also the last time it was done every thing was checked i.e the wheel bearing etc and all seemed well
has any one got any info that may help or the best way to proceed with this issue as it is getting to be
a costly problem and I would like to get it cured.
Tony
Re: REAR AXLE OIL SEAL
Post by Ian » Tue Apr 12, 2011 9:43 am
Moved to techie section.
