Stuck sliding door
JonWM
Stuck sliding door
Post by JonWM » Sat Apr 09, 2011 11:25 am
Hi - is it possible to release a shut sliding door?
if it helps - battery was flat and and jumped it. Open sliding door OK, switrched off engine (only after a minute or so of running so no real charge put baqck in the battery). Shut door - noticed no electrical assistance noise and now won't open - tried everything besides forcing
Jon
Jon
Second bongo
White and Silver T reg AFT with Montague conversion
dobby
Re: Stuck sliding door
Post by dobby » Sat Apr 09, 2011 11:38 am
They always do that after a flat battery :roll:
Needs a really good THWUMP about a third of the way up on the INSIDE with the palm of your had. It should then whirr and click away
Good luck
JonWM
Post by JonWM » Sat Apr 09, 2011 2:37 pm
JonWM wrote:Needs a really good THWUMP about a third of the way up on the INSIDE with the palm of your had. It should then whirr and click away
Hi and thanks but tried this and to no avail. Whereabouts specifically on the inside do i need to assault?
If this doesn't work is there another way - applying external powere supply source to somewhere?
Jon
Jon
Second bongo
dobby
Post by dobby » Sat Apr 09, 2011 2:41 pm
From the inside, about a third of the way up the door panel in the middle.
Just keep on thwumping as hard as you can until it starts working.
The alternative is to take the panel off and poke about but I'm not sure what you need to poke at.
I know that there are other solutions to this so hopefully someone else can help. I've done mine and one other bongo this way though.
westonwarrior
Post by westonwarrior » Sat Apr 09, 2011 2:41 pm
neds to be about half way up the front with the flat of the hand and quite a good thump too
JonWM
Post by JonWM » Sat Apr 09, 2011 5:15 pm
Mucho thankos.
Got the van started again and thumping where you said seemed to do the trick.
TVM
Jon
Jon
Second bongo
dobby
Post by dobby » Sat Apr 09, 2011 6:30 pm
=D> =D>
Great news
