no start
phatgit
no start
Post by phatgit » Fri Mar 18, 2011 10:13 pm
used the bongo this morning to get to work, then come home time bongo wont start,called out the AA, and he says theres no live feed to the glowplug relay. So i'm guessing the fusible link has gone, BUT where is it exactly? both of us were trying to find it but no luck, is it possible to replace it with a normal type fuse of suitable rating? :?: :?:
westonwarrior
Re: no start
Post by westonwarrior » Fri Mar 18, 2011 10:37 pm
right next to the battery
Re: no start
Post by Bob » Fri Mar 18, 2011 10:39 pm
How good is that, nice one WW. =D>
phatgit
Re: no start
Post by phatgit » Fri Mar 18, 2011 11:03 pm
many thanks guys, top banana =D> =D> =D> what size fuse??
westonwarrior
Re: no start
Post by westonwarrior » Sat Mar 19, 2011 6:42 am
I believe 30 amp as thats what I used
phatgit
Re: no start
Post by phatgit » Sat Mar 19, 2011 7:37 pm
Many thanks WW, a picture says a thousand words,found it and replaced with a 30amp fuse. bongo starts a treat......job done :P :P
westonwarrior
Re: no start
Post by westonwarrior » Sat Mar 19, 2011 7:56 pm
Thats what this place is all about
Im very pleased you got going but you should try and get the correct link now from a mazda dealer
phatgit
Re: no start
Post by phatgit » Fri Mar 25, 2011 7:08 pm
the above lasted until last night,30a fuse had popped :shock: ,then again tonight,popped again :shock: .
so i guess i have a dodgy glowplug,(had 2 changed about 2 weeks ago)so the question is what is the resistance of a glowplug when cold and what is it when hot?. i've got a new fusible link coming from belgium in the next couple of days, but not fitting it until i've sorted this problem [-X
daveblueozzie
Re: no start
Post by daveblueozzie » Fri Mar 25, 2011 7:22 pm
Don't know anything about resistance but you should have changed all four glow plugs at the same time, the two new ones are now putting strain on the two older ones. Don't know if this causing the problem but its a good start i would think.
Lost without my Bongo.
wonkanoby
Re: no start
Post by wonkanoby » Fri Mar 25, 2011 7:37 pm
did they use right legnth
is the glow rail clear ie not shorting
phatgit
Re: no start
Post by phatgit » Wed Mar 30, 2011 8:11 pm
Problem solved :) there was a short on the main wiring loom(tight turn into the engine bay). ripped loom apart re-made joint and insulated :P :P :P nice feeling when you've found it :wink:
