SLIDING DOOR IS STUCK CLOSED !!!
yorkshirelass
Post by yorkshirelass » Fri Mar 18, 2011 3:51 pm
JUST got back from shopping when I used side door. On getting home it would not open again; Yes..tried with and without key/fob. All other doors unaffected. The tab thingy goes up/down...same as other doors too. Has the door motor gone/does it have its own motor ? Should mention...that the 'motor noise' has been gong on/off for a long time now.....but only on occasions. I just opened then closed the door again, and this seemed to work.
Anyone had this prob before ? Any suggestions please ?
Re: SLIDING DOOR IS STUCK CLOSED !!!
Post by Muzorewa » Fri Mar 18, 2011 4:01 pm
Try cleaning the contacts at the bottom of the door & frame, the things that look like the valves on a trumpet - should be ok :wink:
Post by mikeonb4c » Fri Mar 18, 2011 4:12 pm
Muzorewa wrote:Try cleaning the contacts at the bottom of the door & frame, the things that look like the valves on a trumpet - should be ok :wink:
How's she going to get the door open to do that? :roll:
I wonder if this is a candidate for the old 'thump it on the inner panel' technique (you'd need to search for advice on how its done YL)
Good luck - keep us posted [-o<
Post by Bob » Fri Mar 18, 2011 4:22 pm
My understanding is a good slap with the flat of your hand can often clear this, there has been a good bit on here in the past.
Don't know if there is a Fact Sheet, but as suggested, once it is open a clean of the contacts can't hurt.
Otherwise I recon slide the seat out of the way and reomove the pannel to have a look inside.
yorkshirelass
Post by yorkshirelass » Fri Mar 18, 2011 4:45 pm
Thanks Bob, Muz & Mike......at least it does not sound expensive...unless I give it a kick :shock: May sound silly but....what do I clean the valve looking thingys with [if I get the door open by the hand slapping method] ? My instinct says a dry wipe over etc then a squirt with dwd ?
Need to know this before I try anything as don't want to leave door open as its parked on the road !
Post by mikeonb4c » Fri Mar 18, 2011 4:58 pm
yorkshirelass wrote:Thanks Bob, Muz & Mike......at least it does not sound expensive...unless I give it a kick :shock: May sound silly but....what do I clean the valve looking thingys with [if I get the door open by the hand slapping method] ? My instinct says a dry wipe over etc then a squirt with dwd ?
You might try metal polish (Duraglit etc.). But most people would probably use a fine wet and dry sandpaper, used wet, to really get off any oxide layer.
Post by Bob » Fri Mar 18, 2011 5:11 pm
Bob wrote:My understanding is a good slap with the flat of your hand can often clear this, there has been a good bit on here in the past.
From Inside. :)
mikexgough
Post by mikexgough » Fri Mar 18, 2011 6:21 pm
From a Japanese Buddy with pictures too
dobby
Post by dobby » Fri Mar 18, 2011 9:05 pm
This normally happens after a flat battery, it needs a good hard thwump from the inside with the flat of your hand. You need to hit it like you mean it :shock:
If it doesn't work then its time to take the door card off etc as per the above link.
