What is this?
briwy
What is this?
Post by briwy » Tue Mar 01, 2011 4:21 pm
Can someone please tell me what this is and what does it lock.
Round plastic thing on the floor below the accelerator pedal, says Lock on it with a clockwise arrow arrow
Re: What is this?
Post by Muzorewa » Tue Mar 01, 2011 4:26 pm
Isn't it the electronic kick-down button :idea:
briwy
Re: What is this?
Post by briwy » Tue Mar 01, 2011 4:39 pm
Don't think so Muz.
My accelerator pedal doesn't go down far enough to touch it, stops about 6mm short and the plastic button is solid when pushed.
Re: What is this?
Post by Bob » Tue Mar 01, 2011 5:07 pm
Does it just hold the carpet in place?
Re: What is this?
Post by rita » Tue Mar 01, 2011 5:15 pm
Hi briwy,
Its the accelerator pedal stopper.
Cheers.
briwy
Re: What is this?
Post by briwy » Tue Mar 01, 2011 5:52 pm
OK thanks, but why does it say lock on it with an arrow?
Re: What is this?
Post by francophile1947 » Tue Mar 01, 2011 5:55 pm
briwy wrote:OK thanks, but why does it say lock on it with an arrow?
Try unlocking it and see if it comes off 8)
Re: What is this?
Post by rita » Tue Mar 01, 2011 6:03 pm
It is in 3 parts,you might be able to adjust and lock it,give it a try and see.
Cheers.
dobby
Re: What is this?
Post by dobby » Tue Mar 01, 2011 9:04 pm
Whatever you do, do not undo it....................................................................... :shock:
Re: What is this?
Post by bigdaddycain » Wed Mar 02, 2011 12:27 am
I think this subject was raised years ago on the forum... The common consensus from memory was the "lock" thing was more an aid when the cap was fitted in the factory on the production line.
skater
Re: What is this?
Post by skater » Wed Mar 02, 2011 1:05 pm
When it's locked no one can steal it........... unless they turn it anti-clockcwise :wink:
On a technical note, in response to post 2, mine kicks down with a short ( 1 ish cm ) fast prod.
Kind of a twitch really.
If you slowly press accelerator alot further it will also kick down but then you get alot of revs in the lower gear.
I prefer the first method which I didn't know about until I read it somewhere ( not Bongo related but tried anyway ).
" it's not rocket surgery! "
