Fuel Gauge - misbehaving
timorr
Post by timorr » Tue Mar 01, 2011 4:09 pm
History:
For the last few months fuel gauge would only read as far a half, even with a full tank
Bongo just back from getting new head gasket
Fuel Gauge stuck on zero, even with full tank
What I have tried:
Following treads and fact sheet I took up the flooring, exposed fuel gauge compartment.
Tried shorting the two cables with no resulting movement on the gauge
Assumed problem must be in electrics away from sensor.
Something else interesting:
I had noticed that when the Bongo came back from the garage that the ash tray light (next to hand break) was not working.
Changed the bulb which now works and straight away the fuel gauge went up to half way (with a full tank)
Turned the engine on and off and now the fuel gauge is again stuck at zero (ash tray light working still)
Before I put the floor back and pulling random wires from under the dash board...could someone please tell me what is the obvious thing I am missing.
Thanks as always
Tim
Re: Fuel Gauge - misbehaving
Post by Bob » Tue Mar 01, 2011 5:10 pm
Poor earth on the sender unit is a common problem, worth duplicating it before you look further.
timorr
Post by timorr » Tue Mar 01, 2011 5:23 pm
Hi Bob, yep thought that also. However would this not be different since when i shorted the two wires there was no change?
wonkanoby
Post by wonkanoby » Tue Mar 01, 2011 5:33 pm
if the tanks not earthed then niether now is end iof that earth wire from it
timorr
Post by timorr » Wed Mar 02, 2011 7:42 pm
OK, so I have followed the earthing guidelines and...
Now the gauge is saying 3/4 full (this could be correct amount)
However it stays up at 3/4 even with the ignition turned off and even with the battery disconnected.
Could this be OK and where is it getting the power to read 3/4 even with no battery?
Also when it made its initial way up to 3/4 full it took about 5 minutes for the needle to crawl up.
mister munkey
Post by mister munkey » Wed Mar 02, 2011 7:48 pm
5 Mins sounds a little bit too long but otherwise it sounds like its working as it should
jaylee
Post by jaylee » Wed Mar 02, 2011 8:09 pm
timorr wrote:OK, so I have followed the earthing guidelines and...
Yep, it normally hold the last position on the gauge with the ignition off...
Is it me or was this threads initial post tagged on here?? :-? :-? http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=47254
Post by francophile1947 » Wed Mar 02, 2011 9:06 pm
jaylee wrote:Is it me or was this threads initial post tagged on here?? :-? :-? http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=47254
Depends when you looked. It may be that I posted on here instead of the other thread, so I deleted my post and reposted where it should have been :oops: Maybe that's what you saw :? :lol:
westonwarrior
Post by westonwarrior » Wed Mar 02, 2011 9:17 pm
Its both of you :^o :^o :^o
Actualy it was tagged on the end of that other thread but as its a new problem needing help, I split it to aid a direct helping hand
Post by francophile1947 » Wed Mar 02, 2011 9:19 pm
:lol: :lol: :lol: I wondered how I'd managed to post on a thread I wasn't looking at :lol: :lol: :lol:
jaylee
Post by jaylee » Wed Mar 02, 2011 9:22 pm
What you are saying is you took Bongowner's post which was initially about 5 posts down & made another thread/topic...? :roll: :lol:
jaylee
Post by jaylee » Wed Mar 02, 2011 9:31 pm
Bongowner is likely to get confused with the notifications... Has any Mods dropped a note through his door??
westonwarrior
Post by westonwarrior » Wed Mar 02, 2011 10:34 pm
Sure have :wink:
