Wired up blanking cover
Dean
Post by Dean » Tue Mar 01, 2011 11:57 am
Whilst fitting my plasma Gauges at the weekend I found a spot for the switch/rheostat, where two switch blanks were. I took one out and then noticed the others had a bunch of wires connected to it...any ideas what it could be. They are on the main dash to the right of the steering wheel
jaylee
Re: Wired up blanking cover
Post by jaylee » Tue Mar 01, 2011 12:00 pm
Front fogs..? Where there 4 wires?? Could also be part of the redundant/south Japan not fitted "winter pack" loom?
From memory.. Red & black coded..?
Post by g8dhe » Tue Mar 01, 2011 12:38 pm
Yup its the front fogs, I used the same place for my display controls, just a tiny bit of trimming of the metal plate and remove the central divider.
jaylee
Post by jaylee » Tue Mar 01, 2011 12:40 pm
Kincaid
Post by Kincaid » Tue Mar 01, 2011 2:58 pm
g8dhe wrote:Yup its the front fogs, I used the same place for my display controls, just a tiny bit of trimming of the metal plate and remove the central divider.
I'm planning to fit some RING driving lamps over the weekend. I've already purchased a fitting kit with relay etc but is using the existing wiring loom and adding a fuse and relay into fuse box also an option then?
Bongo Gymreig
Post by g8dhe » Tue Mar 01, 2011 3:08 pm
Its an option if all the loom bits are there and can be located, BDC found his connectors down by the bumpers, not sure I have seen a spare relay socket up where the relay is factory fitted however (but I haven't looked that hard either!);
Kincaid
Post by Kincaid » Tue Mar 01, 2011 3:22 pm
Cheers Geoff, if I don't decide to use the existing loom -I'll at least put the relay in the right place. It's amazing the level of detail on the wiring diagrams =P~
Bongo Gymreig
Post by bigdaddycain » Wed Mar 02, 2011 12:42 am
I don't know if my bongo is typical of all others, but my bongo didn't have factory fogs. I found a pair of plugs taped up behind the bumper (further inspections revealed the plugs had never been "plugged", and the tape was filthy and brittle indicating it had been there a long, long time)
I had to chop the plugs and spade the wires as i was fitting aftermarket foglights... Upon removing the blank where the "winter pack" switch should live, i discovered wires plugged into the rear of the blank,when i plugged them into a suitable mazda foglight switch i fired up the fogs, and was surprized that they worked! I never found the relay, but i could hear it clicking when the fogs were switched on! :D
I'm afraid i can't remember any more details as it was quite a few years ago when the fogs were fitted originally! :shock:
