cylinder head coolant bleed point
captainphiliptaffski
Post by captainphiliptaffski » Sun Feb 20, 2011 9:34 am
Hi could anyone help me with the correct point to bleed air from the head please, just put a new rad on and want to ensure there are no air pockets left.
longhaul8
Re: cylinder head coolant bleed point
Post by longhaul8 » Sun Feb 20, 2011 9:40 am
If you go on youtube search bleeding bongo there are 3 videos on there show you all you need to know hopefully.
Post by captainphiliptaffski » Sun Feb 20, 2011 10:15 am
Many thanks, brilliant videos, will go and check this right now.
Dave.
Post by Dave. » Sun Feb 20, 2011 8:59 pm
please be carefull to ensure a tight fit in the funnel
The you tube vids are great But it should state A lot more often to use gloves that are deffo water proof as i had a very nasty burnt hand and lots of blisters over my fingers :)
So please wear thick waterproof gloves cos its damn hot hot hot work :)
Post by captainphiliptaffski » Mon Feb 21, 2011 6:08 pm
Cheers dude, got the job done, no burns,no more bubbles(?) and managed to do it all myself with the aid of some pliable wire to hold the funnel with water level visible while checking expansion tank.
Often wondered what "that hose" did....LOL
Thanks once again....Phil.
lazyb5
Post by lazyb5 » Mon Feb 21, 2011 10:52 pm
Lol i had to phone the wife to come and help and bring the washing up gloves as i couldnt put the funnel down :lol:
Post by Northern Bongolow » Tue Feb 22, 2011 5:11 am
captainphiliptaffski wrote:Cheers dude, got the job done, no burns,no more bubbles(?) and managed to do it all myself with the aid of some pliable wire to hold the funnel with water level visible while checking expansion tank.
did you get the bottom hose hot.
Post by captainphiliptaffski » Tue Feb 22, 2011 6:10 pm
Indeed I did, water in the funnel was just short of boiling point by the time I finished, rather warm to the touch!
It took ages to heat up the engine to get the thermostat to open, quite reassuring really!
TTFN
Cpt Phil.
