Rear Speakers Not Working - Why?
james13009
Post by james13009 » Fri Feb 18, 2011 12:26 am
Can anyone suggest why my rear speakers would'nt be working on my 1999 bongo, the rest of the audio works fine.
I've had the side panel off - to check the connection are fine. All looks well. Done an search can 't find any information.
I have an after market radio fitted -maybe this could be the problem?
I was thinking if its not a simple fix then I could trace the wires (If some one knows the colours / where to look) and splice them in to the front speaker.
Any ideas guys?
Re: Rear Speakers Not Working - Why?
Post by g8dhe » Fri Feb 18, 2011 12:30 am
Not all versions had them fitted ?
For wiring see;
The Black printing refers to the original wiring loom, the Blue refers to the standard ISO connector for 3rd Party devices, click the CC symbol for the colour codes, the next page shows the speaker locations so you can work out front/rear left/right etc.
fatcatlawyer
Post by fatcatlawyer » Fri Feb 18, 2011 9:57 pm
I had this "fault" and then realised that somehow my Radio had put all the sound to the two front speakers. Two minutes fioddling got it back into kilta.
ian G
Post by francophile1947 » Fri Feb 18, 2011 10:02 pm
fatcatlawyer wrote:I had this "fault" and then realised that somehow my Radio had put all the sound to the two front speakers.
ian G
:lol: :lol: Embarrassing ain't it - I did the same, with only the rear speakers working :oops: :lol:
321Away
Post by 321Away » Sat Feb 19, 2011 10:11 am
On the back of the stereo are 2 connectors, 1 supplies power and connections, the other is just the rear speakers, so its possible this connector has disconnected.
julian
Post by mikeonb4c » Sat Feb 19, 2011 10:38 am
My rear speakers work, but if I attempt to adjust the front/rear balance so that noise only comes out of back ones, it simply reduces the volume on all 4 speakers. When I fitted the radio unit I couldn't identify separate feed for rear speakers. Must investigate sometime if I can get a round tuit :roll:
