Back window
al & chris
Back window
Post by al & chris » Sat Feb 12, 2011 7:38 pm
Why is the back window on the passenger side of.. bongo none opening. This is where we want to cook would be good to let all the steam out. Can it be changed to an opening window. There seems to be a latch there but does not open. :?:
MAZABON
Re: Back window
Post by MAZABON » Sat Feb 12, 2011 7:40 pm
because of the sliding door i believe :(
Barrington
Re: Back window
Post by Barrington » Sat Feb 12, 2011 7:40 pm
I think its because the sliding door would knock it off??
Music is my Sanctuary!
Re: Back window
Post by teenmal » Sat Feb 12, 2011 7:47 pm
Hi al & chris,
Mazda did fit a window with a fan and vent incorporated ( optional extra),try the scrappies they might be some kicking around..
Cheers..
Re: Back window
Post by g8dhe » Sat Feb 12, 2011 9:10 pm
Yup, this was the modification to get ventilation http://www.lushprojects.com/bongopartsm ... 2of02.html basically the locked window with the top corner cut-out and replaced with a fan!
Diplomat
Re: Back window
Post by Diplomat » Sat Feb 12, 2011 10:15 pm
g8dhe wrote:Yup, this was the modification to get ventilation http://www.lushprojects.com/bongopartsm ... 2of02.html basically the locked window with the top corner cut-out and replaced with a fan!
And all because the rear cigar lighter is on the nearside. Wouldn't it have almost been simpler to have put the kitchen on the offside, where the window can be opened, and worked around the power feed problem?
Frank
They flew, I took up naturism
al & chris
Re: Back window
Post by al & chris » Sun Feb 13, 2011 12:19 pm
Thanks all never even thought of the sliding door so obvious. :oops:
Re: Back window
Post by rita » Sun Feb 13, 2011 4:16 pm
And all because the rear cigar lighter is on the nearside. it have Wouldn't almost been simpler to have put the kitchen on the offside, where the window can be opened, and worked around the power feed problem?
Frank
Hi Frank,
Maybe one of these Feng Shui type of things. We no puta cooka dare. :)
Cheers...
