Caravan towing mirrors ?
Posted: Thu Feb 10, 2011 11:33 pm
Hi guys do i need special towing mirrors to fit the large bongo mirrors or will the universal type suffice ?
Thanx.
Thanx.
A forum for Bongo fans and owners
https://igmaynard.co.uk/bongo/forum/
They are EXACTLY the ones I usedM 80NGO wrote:Thats great, thanx for the info guys
Is this the sort you mean ?
http://cgi.ebay.co.uk/1-pair-caravan-to ... 45f88f8ac4
Bongoplod wrote:They are EXACTLY the ones I usedM 80NGO wrote:Thats great, thanx for the info guys
Brian
If you are towing a caravan wider than your towing vehicle,basically,the law requires that you have towing mirrors.M 80NGO wrote:I don't actually need any extra mirrors after all the bongo being a little bit wider than a normal car i can see perfic, the caravan only sticks out 5" either side of the bongo
Bongoplod wrote:If you are towing a caravan wider than your towing vehicle,basically,the law requires that you have towing mirrors.M 80NGO wrote:I don't actually need any extra mirrors after all the bongo being a little bit wider than a normal car i can see perfic, the caravan only sticks out 5" either side of the bongo
There are measurements for how far you have to be able to see behind you,but id get a set fitted to be on the safe side
Brian
Yes and perhaps other legal requirements,but lets not get racistM 80NGO wrote:Bongoplod wrote:If you are towing a caravan wider than your towing vehicle,basically,the law requires that you have towing mirrors.M 80NGO wrote:I don't actually need any extra mirrors after all the bongo being a little bit wider than a normal car i can see perfic, the caravan only sticks out 5" either side of the bongo
Brian
Ok buddy i best stay the right side of the law, tho it is interesting that our friends from the traveling comunity seem to manage without them
