Caravan towing mirrors ?
M 80NGO
- Location: Usually in My own wibbly wobbly lill world ! Otherwise Huntingdon.
Hi guys do i need special towing mirrors to fit the large bongo mirrors or will the universal type suffice ?
Thanx.
Thanx.
Re: Caravan towing mirrors ?
Normal ones with the 2 rubber straps to attach were fine on mine
Brian
Brian
which ever you buy,make sure they meet the new regs,they have changed in the last few years and must meet certain criteria. i think its CE regs or something,and they have to have it stamped/printed on them.
M 80NGO
Thats great, thanx for the info guys
Is this the sort you mean ?
http://cgi.ebay.co.uk/1-pair-caravan-to ... 45f88f8ac4
They are EXACTLY the ones I usedM 80NGO wrote:Thats great, thanx for the info guys
Brian
M 80NGO
Bongoplod wrote:They are EXACTLY the ones I usedM 80NGO wrote:Thats great, thanx for the info guys
Brian
Thanx Brian
M 80NGO
I don't actually need any extra mirrors after all the bongo being a little bit wider than a normal car i can see perfic, the caravan only sticks out 5" either side of the bongo
If you are towing a caravan wider than your towing vehicle,basically,the law requires that you have towing mirrors.M 80NGO wrote:I don't actually need any extra mirrors after all the bongo being a little bit wider than a normal car i can see perfic, the caravan only sticks out 5" either side of the bongo
There are measurements for how far you have to be able to see behind you,but id get a set fitted to be on the safe side
Brian
M 80NGO
Bongoplod wrote:If you are towing a caravan wider than your towing vehicle,basically,the law requires that you have towing mirrors.M 80NGO wrote:I don't actually need any extra mirrors after all the bongo being a little bit wider than a normal car i can see perfic, the caravan only sticks out 5" either side of the bongo
Brian
Ok buddy i best stay the right side of the law, tho it is interesting that our friends from the traveling comunity seem to manage without them
Yes and perhaps other legal requirements,but lets not get racistM 80NGO wrote:Bongoplod wrote:If you are towing a caravan wider than your towing vehicle,basically,the law requires that you have towing mirrors.M 80NGO wrote:I don't actually need any extra mirrors after all the bongo being a little bit wider than a normal car i can see perfic, the caravan only sticks out 5" either side of the bongo
Brian
Brian
STANIMA
make sure if you go towing mirrors they packed carefully stacked
they could snap, seven years bad luck if the trailer wheel hit a rut
You have cause to tut or even but
like a badly kept cage bear
its not nice if the animal rights get there for the bear i mean. NOT the glass
head it off at the pass & use masses of padding cladding or even Steve McFadden
& those things in boxes like Wotsits, but dont taste so nice,
i offer good advice!
Peace.
Stan.
Peace.
Stan.
