Broken heater radiator pipe.
al & chris
Post by al & chris » Mon Feb 07, 2011 3:13 pm
Stopped at petrol station today then on setting off low coolant alarm came on. On inspection water leaking out from from somewhere under air filter housing. Drove round to my local bongo garage which was only a few hundred meters away. There are two pipes which go into heater radiator and one of them had broken. Thought at first the hose had blown off but the plastic over which the hose fits has sheared. There was enough of a stub left to reconnect the hose but think i will get a new heater radiator. Anyone know where i can get one and has this happened to anyone else.
Re: Broken heater radiator pipe.
Post by Northern Bongolow » Mon Feb 07, 2011 3:20 pm
yes its a common issue.
new/second hand parts are available from the usuall guys,but are expensive, some just bypass the rear heater until one can be found/fitted.
please make sure its bled up correctly.
al & chris
Post by al & chris » Mon Feb 07, 2011 3:28 pm
Its the front one on ours thats gone. Noticed Kirsty had same prob and just re connected to stub like we have .wounder if hers held.
al & chris
Post by al & chris » Mon Feb 07, 2011 3:34 pm
Just shows low coolant alarms work.
Post by Northern Bongolow » Mon Feb 07, 2011 3:38 pm
yes it did. :wink:
Post by francophile1947 » Mon Feb 07, 2011 3:55 pm
al & chris wrote:Noticed Kirsty had same prob and just re connected to stub like we have .wounder if hers held.
Dunno, but she's removed her rear heater completely 8)
al & chris
Post by al & chris » Mon Feb 07, 2011 7:24 pm
Hose now reconnected to the stub. System bled and all seems ok. Been looking on web and cant see many front heater matrix's on there at the moment.
Post by Northern Bongolow » Tue Feb 08, 2011 6:09 am
think bell hill had one for sale on e*ay recently, may be worth a call.
Post by teenmal » Tue Feb 08, 2011 1:01 pm
al & chris wrote:Hose now reconnected to the stub. System bled and all seems ok. Been looking on web and cant see many front heater matrix's on there at the moment.
Hi,you could try these people...............
http://www.vehicleheaters.co.uk/Heater% ... 20852.html
