question about glowplug lengths?
randombit
Post by randombit » Wed Feb 02, 2011 10:38 am
We have long (101mm) glowplugs in the van. do we have to replace like for identical like? can we use short ones instead? also can somebody tell us what voltage they should be.
sorry if these are stupid questions.
trying to prepare it for sale.
wonkanoby
Re: question about glowplug lengths?
Post by wonkanoby » Wed Feb 02, 2011 10:52 am
you could run into problems with the metal rail shorting
if you use shorter..thogh i seem to recal some one doing it
around 12.5 to 13.5 v
randombit
Post by randombit » Wed Feb 02, 2011 11:43 am
excellent just read on compatible parts that they the same as a ford ranger found a set for £25
Post by teenmal » Wed Feb 02, 2011 12:10 pm
Heater plugs are generally rated 11 Volt.
Cheers..
321Away
Post by 321Away » Wed Feb 02, 2011 1:27 pm
Cheap glow plugs @ £25 a set, wont last very long, most recommend NGK as they seem to have the longest life span.
If you use shorter plugs then you will have to 'persuade' the injector loop rail so it doesnt touch the lowered glow plug rail, can be done quite easily.
Julian
Post by teenmal » Wed Feb 02, 2011 1:31 pm
randombit wrote:excellent just read on compatible parts that they the same as a ford ranger found a set for £25
Hi could you tell the manufacturer of the plugs?
Cheers..
randombit
Post by randombit » Wed Feb 02, 2011 1:55 pm
hi not sure of brand but there on ministryofparts.com then look for ford ranger but justfound some ngk ones £6.55 each on mister-solutions part no. y-701j
MountainGoat
Post by MountainGoat » Wed Feb 02, 2011 2:21 pm
I just got a set from Mr Solutions as spare. They are the real deal and you can get any length of NGK glow plugs that you want from them.
Tony
randombit
Post by randombit » Wed Feb 02, 2011 2:27 pm
yeah goin to get ngk ones seem to have a good rep not a bad price either
dandywarhol
Post by dandywarhol » Wed Feb 02, 2011 7:19 pm
Fit cheapos and this can happen - the missing bit rattles about in the pre combustion chamber :shock:
randombit
Post by randombit » Mon Feb 07, 2011 11:10 am
hello again i thought id just check with ngk to make sure i was getting the right glow plugs and that they were 102mm . this is the response i got any ideas folks
The advice you have been given is incorrect as we definitely do not have a suitable glow plug for the Mazda Bongo 2.5, so Y-701J is not compatible with your vehicle.
Sorry we could not be any more help.
Regards,
Mik Peirce AffIMI
Technical Assistant
MountainGoat
Post by MountainGoat » Mon Feb 07, 2011 11:27 am
Normal size NGK glow plugs here. http://www.mister-solutions.co.uk/index ... ion=search Mr Solutions sell many different sizes so they will have the larger ones too if you need them. I purchased 4 off them a month ago, they are the real McCoy.
Tony
MountainGoat
Post by MountainGoat » Mon Feb 07, 2011 11:45 am
Oops! I'm repeating myself. This is the first that I have heard that NGK did not make the larger sized Glow Plugs for a Bongo.
Tony
randombit
Post by randombit » Mon Feb 07, 2011 11:59 am
this is doing my head in i thought i had it sorted out then mr solutions reffered me to ngk technical and neither will tell me a part number that will work aaaargh!!!
Post by Ian » Mon Feb 07, 2011 12:20 pm
I can confirm that NGK do not manufacture a 102mm plug. But you can get Blueprint ADK81801, Ford F1441267 or Nipparts J5718000.
