Gell cell or normal LB?
mcbainia
Post by mcbainia » Fri Jan 21, 2011 11:02 pm
Ive got a numax l110 LB and I'm charging it up using my battery charger. There's a setting on my charger for a 'gel cell' or a 'normal'. Does anyone know which setting it should be on? Does it make a difference?
You can lead a horse to water but you cannot make it swim
daveblueozzie
Re: Gell cell or normal LB?
Post by daveblueozzie » Fri Jan 21, 2011 11:15 pm
Im sure it would say on the battery whether it was a gel battery
Lost without my Bongo.
Post by g8dhe » Fri Jan 21, 2011 11:16 pm
The Numax L110 is a standard Lead Acid whilst Gel Lead Acid batteries are sealed with a pressure relief valves.
The charger will use a slightly higher charging voltage and current for standard batteries whilst it is important to keep the current slightly less in the Gel types as if they start to gas to much then you will cause the valves to open to vent the excess pressure, once the gasses are lost then they can't be replaced by more liquid and the cells will loose performance.
So for a Numax you can use the standard setting.
mcbainia
Post by mcbainia » Fri Jan 21, 2011 11:16 pm
No, no mention of gel at all on the battery.
mcbainia
Post by mcbainia » Fri Jan 21, 2011 11:17 pm
Thank you Geoff. It's now charging away!
