Thanx
Glow plugs ?
M 80NGO
- Location: Usually in My own wibbly wobbly lill world ! Otherwise Huntingdon.
Glow plugs ?
I'm gonna change my glow plugs they're working ( well getting 12 volts ) but i'm suffering the smokey lumpy start ups even now the weather's warmed up but after looking on E-Bay there seems to be a vast range of prices for what looks like the same thing. What plugs do i need for my 1995 2.5 diesel 4x4 ?
Thanx
Thanx
AlliDelta
Re: Glow plugs ?
You need NGK Y701J
Search eBay I got a set of 4 delivered for £32
Words of advice if you are doing the job yourself:
You need to remove the centre console bridge where the gear lever and handbrake attatches, after that there are a group of solonoid relays with pipes on, unbolt these from their mounting plate to facilitate access. Following my debarcle with a sheared off glowplug head I would definitely recommend a good period of time soaked in wd40 to help loosen up the threads, at least overnight. Also ensure you have the engine nice and hot before you attempt to remove the old plugs, all these things I never did and hence I now have a 3 plug Bongo
However I reckon before I did the job she was on 2 plugs at the most and starts perfecly fine on 3 plugs, I simply set the revs to around 1500rpm for about 15 seconds and the lumpyness is gone after this.
Hope this helps.
Hope this helps.
Re: Glow plugs ?
take special care of the solenoid/pipes as these are very brittle,the ends of the solenoids crack off.
MountainGoat
Re: Glow plugs ?
You don't even need to go on e.bay, you can get genuine NGK glow plugs from Mr solutions for £32.88 post free. www.mister-solutions.co.uk. I got four plugs from them recently for back ups, this was the source recommended by You've Been Bongod in a post not long ago. Y701J is the right size for a 1995 Bongo.
Tony
Tony
M 80NGO
Re: Glow plugs ?
Great responces there guys thanx, i'll get em ordered up and do the deed next weekend.
Re: Glow plugs ?
Its worth wd 40 on the bolts hold the gear shift on
i sheared one of removing it as dont think it had ever been removed before
and had loctite or similar on it
