HELLO EVERYBODY!!!!!!!!!
vincie1979
Post by vincie1979 » Thu Jan 13, 2011 6:41 pm
hello everyone just like to say a quick hello to my fellow bongo owners, ive had my bongo for one month now i brought it for me and my little son of 4 years old who is learning to do motocross and we needed a van and a car so the bongo looked like the right choice (2IN1). ive had quite a few issues with it first it was a cv joint then a wheel bearing then a faulty oil filter leaking and now ive got the dreaded HOLD FLASH LIGHT on, ive tryed looking at the bongo fact sheets about trying to find out what code it is and its says depending on how many times the hold light flashes when diagnosing the problem, some of the code numbers range from code 1 all the way to code 60 somthing NOW does this mean the hold light flashes 1 time or 60 times ect... depending on the fault???????? this i dont know and would really be greatfull if anyone could help me on this matter as i really need to get this problem sorted as its driving me mad and i dont dare drive it with this hold light flashing.PLEASE SOMONE HELP ME THANKS :oops: :x :x :x :x
Re: HELLO EVERYBODY!!!!!!!!!
Post by francophile1947 » Thu Jan 13, 2011 7:06 pm
Welcome to the madhouse :D Have a read of this http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=29471 - there may be somebody near you who could help. Have you done the wiring work to the ECU to check the flashing light signals? If so, what are the readings?
vincie1979
Post by vincie1979 » Thu Jan 13, 2011 10:11 pm
hi there thanks for reply, no i havnt yet done the wire thing, im still not to sure how to read the flashing hold light, it says there are many fault codes ranging from 1 flash to 60 somthing flashes is this right?? ive got an idea how to wire to the ecu but im not sure how to read the flashing bit!!!
westonwarrior
Post by westonwarrior » Thu Jan 13, 2011 10:43 pm
Hi and welcome
the code flashes in sequence like 6 fast flashes pause 3 slow flashes = 63 long pause then the next number
However I remember it being the oposit but thats probably my memory
is it on all the time or flashing?
Post by Bob » Thu Jan 13, 2011 11:19 pm
Welcome aboard. :D
vincie1979
Re: got the code i think lol!!!!!!
Post by vincie1979 » Fri Jan 14, 2011 3:53 pm
ive just done the wire thing and its flashing 7 times. and i think its a speed sensor whatever that means????? is it a big problem and or how do i get it fixed many thanks for all your help????????? :) :) :)
Post by g8dhe » Fri Jan 14, 2011 4:08 pm
You don't say which vehicle you have but assuming its a Diesel then the Speed Sensor is shown as B2-18 and its connector is located here;
Otherwise go to the Index pages at the rear and look up Speed Sensor and select the correct engine type!
aitch
Location: in a place far, far away, well Somerset for now!!!
Post by aitch » Fri Jan 14, 2011 8:41 pm
Welcome to the forum - sorry too techy for me to help but hope you get it fixed soon.
westonwarrior
Post by westonwarrior » Fri Jan 14, 2011 11:12 pm
thread continues here
http://www.igmaynard.co.uk/bongo/forum/ ... 17&start=0
locking this one to aid continuity
