Side Door Rattle & Fit
clive and val
Post by clive and val » Thu Jan 06, 2011 1:51 pm
When the Bongo side-door closes I hear the motor pulling in and then out slightly but the rear top of the window does not fit flush with the body work. If I hit a small bump when driving there is a loud rattle from the door as though it is not being held correctly. I don't remember either of these problems occuring some time ago so suspect something in the door has changed. Can the door latch be adjusted to fix these problems? Clive
Re: Side Door Rattle & Fit
Post by mikeonb4c » Thu Jan 06, 2011 3:22 pm
clive and val wrote:When the Bongo side-door closes I hear the motor pulling in and then out slightly but the rear top of the window does not fit flush with the body work. If I hit a small bump when driving there is a loud rattle from the door as though it is not being held correctly. I don't remember either of these problems occuring some time ago so suspect something in the door has changed. Can the door latch be adjusted to fix these problems? Clive
Interesting - I have a similar occasional mysterious noise (didn't used to be there) and am wondering if the cause is similar to yours (hard to check when driving on your own!!!). I'll be interested to see what replies you get 8)
Dr.Jekyll
Post by Dr.Jekyll » Thu Jan 06, 2011 4:43 pm
"...........but the rear top of the window does not fit flush with the body work. Can the door latch be adjusted to fix these problems? Clive
Same here... not found a way to fix it yet.
Post by Northern Bongolow » Fri Jan 07, 2011 5:43 am
the sliding door mountings have been known to come loose on the door side,when this happens the door doesnt shut fully,it can be a pig to adjust correctly.
Post by bigdaddycain » Sat Jan 08, 2011 2:06 am
I'd adjust the top bolts so that they are somewhere between tight, and loose. Imagine they are just tight enough so the door can be pulled/pushed into the desired position when closed. Close the door. Using firm, but not violent pushes/pulls move the door in such a fashion that the window lines up with the other. Then open the door, and tighten the bolts up whilst holding the door firmly so that the flange doesn't move until the bolts are tight. Try the door a few more times to ensure it repeatedly closes "lined up". It may be worth scoring circles around the bolts for future reference in case the bolts ever work loose again. :wink:
Dr.Jekyll
Post by Dr.Jekyll » Sat Jan 08, 2011 8:33 am
I think I will give this a go. Thanks.
clive and val
Post by clive and val » Wed Jan 12, 2011 9:34 am
Thanks to bigdaddycain for the suggestions hope to try to fix it over the weekend. Sorry not to have responded sooner but been away for a few days.
Clive
