broken front windscreen wiper tube - replacement?
eppiblue
Post by eppiblue » Wed Jan 05, 2011 1:12 pm
-15 in Italy managed to snap my wiper fluid tubing when I lifted the bonnet, do I need to order anything specific for replacing? I had a few searches on the forum but couldnt find anything...
'Vincent' - 1996 P reg - Green - 2.5 TD - 4WD - Likes: Diesel, Bitumen and Snow.
Re: broken front windscreen wiper tube - replacement?
Post by francophile1947 » Wed Jan 05, 2011 1:17 pm
I would think most (if not all) washer tubing is the same. Any local garage should be able to help 8)
ChrisQ
Post by ChrisQ » Sat Jan 08, 2011 10:51 am
you can buy replacement tubing from B&Q by the metre, but the simplest thing is to by a pack of tube connectors ( also B&Q) . you need 3mm size. Cut out the damaged part and slip in a male/male connector.
job done.
Worked a treat for me.
ChrisQ
helen&tony
Post by helen&tony » Sat Jan 08, 2011 3:12 pm
Model shop...silicon fuel tubing
Aquarium supplies...air tubing...and complete range of t-pieces , elbows, etc. at either
eppiblue
Post by eppiblue » Sat Jan 08, 2011 3:21 pm
cheers all, got some tubing from B&Q - all done and working. thx
