heater plug relay??
mattnicks
heater plug relay??
Post by mattnicks » Mon Jan 03, 2011 2:37 pm
Hi everyone,
Have just had the bongo serviced and been running fine until yesterday, turned over but wont start, after much reading on heater plugs etc I opted to putting 12v straight to the heater plug rail and she started first turn after brief warm with plugs, does this confirm that the heater plug relay is dead? and if so why did it go straight away? or is there something I am missing?
Any pointers much appreciated.
Cheers Matt
Re: heater plug relay??
Post by francophile1947 » Mon Jan 03, 2011 3:31 pm
Did the glowplugs get changed in the service? If so, it could be the wrong ones fitted and shorting out the rail.
mattnicks
Post by mattnicks » Mon Jan 03, 2011 4:01 pm
Yeah the plugs got changed in service about two weeks ago and been running fine, when you say short out does mean the heater plug rail touching something else? the reason I ask i that the rail has a black plastic coating over it and I cant see anything else touching.
The service was done in a garage and I would like to think they matched the plugs up!!!
Have been looking at new relays and they aint cheap, is there a cheaper alternative mod I can do?
Thanks matt
Post by haydn callow » Mon Jan 03, 2011 4:10 pm
Under the bonnet on the drivers side.....the positive terminal of the Battery....there is the fuseable link to the glow rail.......probably burnt out.....replace it or use a 30/40 amp inline fuse to check it out......BUT FIRST....make sure the rail is well away from the head....somthing must have made it blow.
Post by francophile1947 » Mon Jan 03, 2011 4:35 pm
mattnicks wrote:Yeah the plugs got changed in service about two weeks ago and been running fine, when you say short out does mean the heater plug rail touching something else? the reason I ask i that the rail has a black plastic coating over it and I cant see anything else touching.
Thanks matt
There are mainly 83mm plugs, but some had 102mm fitted. Fitting the shorter plugs, without one of various mods, can cause the rail to short out against the fuel injector pipes. Does the rail look very close to the fuel pipes - particularly underneath? i.e. almost touching.
mattnicks
Post by mattnicks » Mon Jan 03, 2011 4:50 pm
not really to be honest, there looks like plenty of room, will double check now tho to make sure.
Have checked the fuses and they look fine.
thanks
mattnicks
Post by mattnicks » Mon Jan 03, 2011 5:15 pm
#-o #-o #-o the rail is touching the injector pipes but cant see if the black plastic has worn through but I reckon thats whats done it then!! Have spoken with mechanic and he will sort it in the morning fair play. Should the fuse not have gone first?
Thanks for your help
Post by haydn callow » Mon Jan 03, 2011 5:37 pm
mattnicks wrote:not really to be honest, there looks like plenty of room, will double check now tho to make sure.
thanks
This is not a Fuse as such....just a bit of meltable wire connected to the Pos terminal
mattnicks
Post by mattnicks » Mon Jan 03, 2011 7:40 pm
Ah I see, does it connect directly to positive terminal? will check in the morning.
Post by haydn callow » Mon Jan 03, 2011 8:06 pm
Yep !!! just a short length of dirty black wire
mattnicks
Post by mattnicks » Tue Jan 04, 2011 12:47 pm
Right, replaced the fused wire with a 30amp inline fuse for now, raised the heater plug rail clear of any contacts, but keeps blowing the inline fuses i put in #-o any Ideas?
Post by haydn callow » Tue Jan 04, 2011 12:52 pm
Perhaps 30 amps is not big enough.....large current drawn.....best get it back to the garage....
Post by francophile1947 » Tue Jan 04, 2011 1:04 pm
Can you see any arcing, under the bar, before the fuse blows?
dandywarhol
Post by dandywarhol » Tue Jan 04, 2011 1:09 pm
30A fuse too light - plugs draw about 15A each from memory........................
mattnicks
Post by mattnicks » Tue Jan 04, 2011 1:33 pm
No arching and have traced wires back as far as I can to check for any other arching but no sign..
What size fuse do you recommend trying then?
