Bongo heater- not working
not so old
Post by not so old » Tue Dec 21, 2010 3:23 pm
Hi, The Bongo heater isnt working...not good in this weather! I thought it must be the heater fan resistor again and my son fitted a new one, but still not working. Fuses seem ok. Can anyone help Please [-o< Tammy cant stand the cold!
Cheers Anna
Re: Bongo heater- not working
Post by mikeonb4c » Tue Dec 21, 2010 3:38 pm
not so old wrote:Hi, The Bongo heater isnt working...not good in this weather! I thought it must be the heater fan resistor again and my son fitted a new one, but still not working. Fuses seem ok. Can anyone help Please [-o< Tammy cant stand the cold!
Cheers Anna
Need to use a process of elimination I guess. For example (assuming its the front heater fan):
1) Is blower working on any settings between 1 and 4 (if so, suspect resistor, as if the fan is 'tight' to turn it will always end up getting hot and desoldering its contacts) (if not, check relevant fuse - can't remember which it is but its in the factsheet I think)
2) Remove air scoop under bonnet (v. quick and easy) and see if fan is turning freely. If not, that needs addressing by a strip-down and lubricate (ooooh matron) etc..
3) try and connect 12v direct to fan, bypassing resistor etc. If fan doesn't turn, suspect bushes etc.
No doubt Kirsty will be along with more intelligent advice but that's my take on it anyway 8)
not so old
Post by not so old » Tue Dec 21, 2010 3:43 pm
Cheers Anna
Thanks mike.
The blower doesnt work at all
A new resistor didnt work
THe fan moves freely
Ther doesnt appear to be any power going to new fan resistor
They are baffled :(
Post by missfixit70 » Tue Dec 21, 2010 3:49 pm
Hi Anna, if it's the fan not blowing, then I'd suspect the fan itself may well be siezed/sticking due to water ingress, especially if it hasn't been used much, that's usually the reason for the heater fan resistor goes in the first place, just replacing that doesn't fix the problem, just masks it for a while. Worth checking ALL the fuses if you haven't already, this thread - http://www.igmaynard.co.uk/bongo/forum/ ... er#p465889 - shows where they are as well as the FAQ with all the links for checking & fixing the heater motor, not a difficult job for anyone with a bit of mechanical savvy. if you've got the manual slider heater controls, then the heater fan resistor is usually fixable if that's gone again.
not so old
Post by not so old » Tue Dec 21, 2010 4:00 pm
missfixit70 wrote:Hi Anna, if it's the fan not blowing, then I'd suspect the fan itself may well be siezed/sticking due to water ingress, especially if it hasn't been used much, that's usually the reason for the heater fan resistor goes in the first place, just replacing that doesn't fix the problem, just masks it for a while. Worth checking ALL the fuses if you haven't already, this thread - http://www.igmaynard.co.uk/bongo/forum/ ... er#p465889 - shows where they are as well as the FAQ with all the links for checking & fixing the heater motor, not a difficult job for anyone with a bit of mechanical savvy. if you've got the manual slider heater controls, then the heater fan resistor is usually fixable if that's gone again.
Thanks Kirsty, It's a new resistor(in today), so I will tell them to check the fuses again as you suggested and the fact sheets thanks a lot :D
Cheers Anna
Post by missfixit70 » Tue Dec 21, 2010 4:04 pm
You have a pm.
Post by mikeonb4c » Tue Dec 21, 2010 4:08 pm
Good luck Anna. It can't be that tricky and it WILL get it sorted, I'm sure of that. Obviously check fuse first, but have they tried putting 12v direct to the fan motor in order to make sure it is working (its not impossible that the brushes are knackered - if so I seem to recall Stilldesparate successfully replaced brushes, or was it the springs on part-worn brushes, with some generic ones - worth a search on here for old threads while the blokes are freezing their grubby hands off doing hands-on :lol: )
Post by francophile1947 » Tue Dec 21, 2010 4:11 pm
Why bother Anna :? You get enough hot air from Jimmy :lol: :lol:
Incidentally, the diagram, in the link that Kirsty posted, shows fuse 18 in the fusebox under the bonnet, but the factsheet shows fuse 17 :?
not so old
Post by not so old » Tue Dec 21, 2010 4:18 pm
francophile1947 wrote:Why bother Anna :? You get enough hot air from Jimmy :lol: :lol:
Cheeky Beggar :lol: :lol: It's not me that needs the hot air(I cant get in Bongo ) Its Jimmy And Tammy. I get an enough of Jimmy's hot air :lol: :lol: So is it 17 or 18 ? I guess they could try both.
Cheers Anna
Post by francophile1947 » Tue Dec 21, 2010 4:27 pm
not so old wrote:Cheeky Beggar :lol: :lol:
Moi :shock: Image
p.s. no idea which is the correct fuse :oops:
not so old
Post by not so old » Tue Dec 21, 2010 4:59 pm
Moi :shock: Image
Wat!!! Smoke in your eyes John Image :lol:
Post by g8dhe » Tue Dec 21, 2010 6:00 pm
The two fuses to look at are;
and
not so old
Post by not so old » Tue Dec 21, 2010 6:09 pm
g8dhe wrote:The two fuses to look at are;
and
Thanks :) I know it sounds daft, but Jimmy doesnt know where to look for the fuses :roll:
Cheers Anna
Post by mikeonb4c » Tue Dec 21, 2010 6:49 pm
Cheers Anna
removable panel on the front fascia, to the right and down from the steering wheel column, from memory just above where the bonnet pull catch is. It has a gripping slot and just pulls off.
Post by missfixit70 » Tue Dec 21, 2010 6:50 pm
T'other ones are under the bonnet, roughly in the middle with a black clip off cover on.
