Recently purchaased a bongo 95 WT type turbo 2.5L Diesel. On whole very good
I have a problem of the Hold light showing which when diagnosed (according to the Transition error code pdf doc) came up as code 12 (throttle Position Sensor) I am trying to diagnose further...
The vehicle does not kick down when i floor it ( i have to manually select d2/d1 for that) tends to iddle in a top gear on rd and rev down sometimes when going at steady speed/steady revs - in urban areas i find it best to go to d2 to prevent this as it gives me more control.
just wondered what i should do as HOLD light is Anoying, should I turn the TPS screw located somewhere on fuel pump on drivers side hatch (where, what's it look like?)
bit clueless to all this as never even doen an oild change before but quite willing to give things a quick go, Otherwide the bongo drives well auto fluid is a over fill level as I checked this
anybody got any ideas - have searched around and found a pic of the TPS but the piucture was not labelled so not sure what i should be doing also have tried looking under gear stick (auto) for a sensor and not found anything /can't get it off
help please if oinly pointers to documents been reading for days it seems
rgds Paul (North Wales)
